Z300: Alarm
Old 10-04-2010, 02:57 AM   #1
Oregondunes's Avatar
My Model: Z302 Bow Rider
My Engine: 7.4 bravo3
Gallery Images: 36
Send Oregondunes:
Default Z300: Alarm
I just bought a z300 this past weekend. Out of no where this alarm starts beeping and wouldn't stop. All the gauges were within range.
What is it trying to tell me ?
I turn the boat off for 20-30 seconds and started it back up and it went away, till I was near the dock and it started back up.
  • Old 10-04-2010, 12:16 PM   #2
    Default Re: Z300: Alarm
    The Mercruiser warning alarm tells you 3 things.
    1) High Engine Temperature
    2) Low Oil Pressure
    3) Low Gear Lube Level
    Chances are, it's the gear lube reservoir. it's a plastic reservoir mounted on the port side of the engine. If it's full, the odds are that the sensor has gone bad. The whole reservoir with sensor will need to be replaced ($47 part). This is a fairly common problem.
    If it's not the gear lube reservoir, it could be one of your other sensors. You can locate the sensors by finding the tan wire with the blue stripe.
    Old 10-05-2010, 12:31 AM   #3
    Gallery Images: 36
    Send Oregondunes:
    2) Low Oil Pressure
    What is considered High engine temp ? Mine runs right under 170 degrees at full tilt, lower when were idling.
    Oil pressure is 25 at idle and 40+ at speed.
    Haven't checked the gear lube level....Ill do that next.
    Old 10-05-2010, 01:33 AM   #4
    Boatcrazy is currently offline
    My Model: Z302
    My Engine: 502 MPI / Bravo III
    Gallery Images: 548
    Send Boatcrazy:
    Your 170 temp sounds within range but your oil pressure at idle is a tad bit on the low side but I do not think it is so low to cause the warning buzzer to go off.
    Old 10-05-2010, 01:34 AM   #5
    My Model: Z302
    Gallery Images: 548
    Send Boatcrazy:
    Welcome to the club btw. Great looking boat.
    Old 10-05-2010, 02:17 AM   #6
    Gallery Images: 36
    Send Oregondunes:
    1998 Z300 Shabah $26,500 justin_132 Mariah Boats For Sale & Wanted 1 07-18-2010 11:47 PM
    Z300 New Carb Start 95Z212 Original Mariah Talk 3 09-10-2009 02:04 AM
    Just upgraded to a z300. Any others out there? Aquahead Introductions 1 09-09-2008 04:44 PM
    Tons of Mariah Z302 & Z300 Pictures Boatcrazy Original Mariah Talk 1 09-22-2007 03:49 AM
    There are 461 users
