Trying to locate the alarm
Old 10-02-2010, 09:24 PM   #1
elimont is currently offline
My Model: Barchetta 182
My Engine: 4.3 Alpha
Send elimont:
Default Trying to locate the alarm
There are warning stickers on the dash about the alarm but I am unable to find it.1996 182 Barchette. When turning the key to on there is no alarm. I am betting the previous owner unhooked it. I would like to hook it back up. Could the alarm use the horn? Right now the horn is not working either I found and removed that and will be replacing . My winter project is to go through this boat and undo every thing the last guy did. He took great care of the boat clean, shiny and maintained but his wiring is scary. Removed the stereo, fish finder and off shore radio so far.
  • Old 10-02-2010, 10:23 PM   #2
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    Default Re: Trying to locate the alarm
    elimont,
    If it like mine, it is a small black hockey puck shaped item about two inches in diameter and about a half of an inch thick. Mine is fastened to the underside of the glasswork just about under the windshield (starboard side).
    I haven't found the horn yet.
    Shabah 198SE
    Old 10-02-2010, 10:37 PM   #3
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    If it's in the same place as it is on our 1994 182 Barchetta, it's up under the dash, on the starboard side. It's a small, round, aluminum "can" kind of a thing, IIRC.
    Could be. Ours had. Turn the key to run, w/o starting. The alarm should sound w/in about 10-20 seconds.
    Good idea!
    Nope. Separate sounder.
    That's typical. We have the same on our sailboat. I have yet to address all that. Someday... Luckily the PO of our Barchetta hadn't messed with her
    Welcome to MOC!
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 10-03-2010, 12:42 AM   #4
    Send elimont:
    My horn was also where you are saying your alarm is. I had to almost stick my head in the access from the bow and it was mounted against the outside. I felt around everywhere and still no alarm will look tomorrow when its light again. I also tried finding the wire tan/Blu to try to trace it to the alarm. I have yet to find that either.
    Alarm Shabah 198SE Original Mariah Talk 14 08-31-2010 02:38 AM
    Alarm florida22 General Maintenance 2 06-20-2010 01:05 PM
    why is my alarm going off ? Wurknman Original Mariah Talk 6 06-19-2009 08:44 PM
    Alarm? jmo Mercury MerCruiser 3 09-09-2008 02:09 AM
    alarm Mark Original Mariah Talk 10 11-26-2007 05:49 PM
    There are 655 users
