Depth finder inop
Old 08-30-2010, 02:44 PM   #11
Default Re: Depth finder inop
You must use epoxy to secure the transponder because it remains acoustically transparent after curing.
  • Old 08-30-2010, 02:49 PM   #12
    mosky's Avatar
    mosky is currently offline
    My Model: 202
    My Engine: 5.0L Alpha
    Send mosky:
    Exactly what i learned the hard way. Somewhere i had read to use the 3M 5200 adhesive instead of epxoy. just goes to show you that you can't believe everything you see on the internet.....
    Old 08-30-2010, 05:04 PM   #13
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    I had the boat out this weekend and the depth finder worked most of the time. Who knows. It might not be worth tearing into it.
    Patrick
    Old 08-30-2010, 05:09 PM   #14
    Its not a difficult job to remove & reset the transducer but the access to it can be a little tight.
    Tis your boat & your call on repairing it so that it works all of the time. Personally i dont like the idea of grounding my outdrive.....
    Old 08-30-2010, 05:14 PM   #15
    Send theeasynine:
    Good point.
    Yes I've found my 6'3" frame doesn't fit well in the engine compartment. It sounds like a good winter job.
    Patrick
    Old 08-30-2010, 06:27 PM   #16
    Just remember you can't test to make sure it works in the water during the winter!
    Old 08-30-2010, 09:33 PM   #17
    Send theeasynine:
    I found the transducer under the engine. I can pull it up by the wire, but I'm not sure I can get an arm down there to expoxy it to the hull.
    Would waterproof silicone work to reattach it?
    Patrick
    Old 08-31-2010, 12:36 AM   #18
    Sorry, but what part of "You must use epoxy' didn't you understand?
    Old 08-31-2010, 01:43 AM   #19
    Send theeasynine:
    Okay okay..
    Thanks everyone for their patience with this Mariah newbie!
    Patrick
    Old 09-02-2010, 05:12 PM   #20
    Send theeasynine:
    Update!
    I expoxy-ed the transducer back down in the hull today. I'll let you know if it fixes it when we take it out this weekend!
    Patrick
    Depth finder woes NogginDoc Boating 101 1 07-19-2010 04:35 PM
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth Finder works the first minutes then mad ebb8827 Original Mariah Talk 8 03-23-2010 03:52 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    Aftermarket Depth Finder Suggestions? stereoman405 Original Mariah Talk 0 06-25-2009 05:33 AM
    There are 137 users
