hi rev-maybe spun prop-omc outdrive
Old 08-22-2010, 05:15 PM   #1
rusty's Avatar
rusty is currently offline
My Model: 1998 shabah Z210 5.7L b-III
Send rusty:
Default hi rev-maybe spun prop-omc outdrive
HELP FOR FRIEND !
A friend just bought a used boat recently,test drove it,all seemed good.(unfortunately it's not a mariah).It's an 18 ft. with a v-6 and an omc outdrive-early 90s model.Yesterday,after running about 15 minutes and at about 3/4 throttle,the engine began over-reving and the boat quit going!Basically my thoughts were a spun prop.There was a smell of burnt rubber coming from the engine compartment like a belt.The temp was in the normal range.shut the boat down for about an hour then tried running it again and it would run at idle and slightly above.We tried this to head back to the landing but after everything warmed back up it quit pulling again.I towed him on in.at the ramp,same thing-will pull at idle before warming back up.I'm still thinking spun prop,but the rubber smell is puzzling me.I'm not that familiar with the omc.
Any input would be much appreciated.Thanks.
  • Old 08-24-2010, 05:21 AM   #2
    aaron999888's Avatar
    aaron999888 is currently offline
    My Model: 244 Jubilee
    My Engine: 7.4L Penta DuoProp
    Gallery Images: 38
    Send aaron999888:
    Default Re: hi rev-maybe spun prop-omc outdrive
    A couple years ago I was on my dads boat when something similar happened with that same burnt rubber smell.
    If I remember right it was a damaged gimbal.
    Old 08-24-2010, 10:53 AM   #3
    That sounds like a bad engine coupler. The coupler is a round metal piece on the back of the motor that has rubber "insides". It's a pretty significant repair, which involves removing the engine and outdrive from the boat. Don't ask me how I know about this...
    Old 08-24-2010, 12:42 PM   #4
    Dutch180SE's Avatar
    Dutch180SE is currently offline
    My Engine: 4.3LX Alpha I gen II
    Gallery Images: 2
    Send Dutch180SE:
    Chris, how do you know about this ?
    Mike
    1998 Shabah 180 Supersport 4.3 V6 Alpha I
    Save a tree, eat a beaver..
    Old 08-24-2010, 02:40 PM   #5
    Mine went last year.
    Old 08-25-2010, 12:39 AM   #6
    rusty's Avatar
    Send rusty:
    Hey thanks for all the input.That sounds logical.The most puzzling part to me is how it worked to some degree once everything cooled down.Guess it's time to pull the motor/outdrive.wonder how many beer that will take!!
    Where can I find an outdrive? jasfiveo Original Mariah Talk 3 07-15-2010 09:17 PM
    Outdrive 96blackmariah Original Mariah Talk 6 06-22-2009 04:11 PM
    How common is a spun prop? abillmann Prop Talk 10 06-14-2009 04:26 PM
    1993 2350Z prop and outdrive cleah General Maintenance 2 11-21-2008 10:08 PM
    Refinishing the Outdrive bdbyrnes Projects 2 04-16-2008 05:43 PM
    There are 237 users
