Trolling Motor Mount-180 Talari
Old 08-16-2010, 02:22 AM   #1
Talari95's Avatar
Talari95 is currently offline
My Model: 180 Talari
My Engine: 4.3L Alpha One
Send Talari95:
Default Trolling Motor Mount-180 Talari
OK, I realize that many Mariah owners consider mounting a trolling motor on their boats a sin. However, like many boat owners, I had to make a compromise when it came to a family boat, so have a 1995 180 Talari on which I just mounted a trolling motor.
I thought I would share my experience, especially since there is no access to the underside of the bow on the Talari which makes mounting a trolling motor mount challenging.
I specifically purchased a Minn Kota Powerdrive trolling motor because of the small footprint of the mounting bracket (MKA-21). The only part that is permanently mounted to the boat is a small (~4" x 5") composite puck.
I first taped off the area I would be mounting the motor. After determining where the mount would be placed and marking the hole location, I drilled four 1/8" pilot holes (always start by drilling holes with drill in reverses to avoid chipping the gel coat) and then drilled four 1/2" holes. I inserted 1/4-20 Snaptoggle anchors through the holes along with a rubber washer (to help minimize vibration). After tightening the Snaptoggles, the excess part of the toggle is trimmed. The puck is mounted with four 1/4" stainless steel bolts. I also glued four rubber washers to the underside of the puck to help eliminate any vibration. The remainder of the mount is attached to the underside of the trolling motor.
All in all it doesn't look too bad. The motor mounts easily and all electical connections are out of sight under the starboard bow seat.
Carl
Carl
1995 180 Talari
4.3L Mercruiser
Alpha One
  • Old 08-17-2010, 08:32 PM   #2
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Default Re: Trolling Motor Mount-180 Talari
    Looks like a nice clean install. Thanks for sharing.
    Do you have a swivel seat up there? I saw one a while back that had a base that swapped out with the bow filler cushion and cooler lid. Pretty slick.
    Old 08-18-2010, 02:03 AM   #3
    Talari95's Avatar
    Send Talari95:
    I am working on that design right now.
    Carl
    1995 180 Talari
    4.3L Mercruiser
    Alpha One
    Old 08-22-2010, 02:41 PM   #4
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    You'll burn in Hell!!
    Just kidding, it is a good looking install.
    I saw a trolling motor mounted on a Glastron Simitar before. Talking about strange!
    trolling motor cadditguy Prop Talk 3 08-13-2010 06:17 PM
    Mounting Trolling Motor Talari95 Original Mariah Talk 3 07-12-2010 10:14 PM
    '98 Z211 Talari Sport Cuddy - Loaded - New Motor - WA State stereoman405 Mariah Boats For Sale & Wanted 0 06-10-2010 05:34 PM
    Need to mount Auxillary Motor TomasSE Sea Fox - Mariah Talk 2 04-28-2010 03:55 PM
    cracks in floor pan under engine mount luke Original Mariah Talk 1 02-22-2008 12:21 PM
    There are 280 users
