7.4L in a Shabah
I have a 1995 Z202 shabah with a 7.4L bravo III. Is this even an option for this boat? All the information I have been able to find lists the 5.7L as the biggest available motor. I just want to make sure this boat is rated for that motor.
Re: 7.4L in a Shabah
The '95 brochure shows the max horsepower at the prop to be 275 and the 350MAG as the largest engine option. I believe the 7.4 puts out around 310hp....that should be one hell of a fast boat.:eek_animated:
do you know how this boat could have ended up with that motor?
i dunno....somebody installed it? :rolleyes:
Do you have any pictures... I'd love to see your boat.
We have a 95 202 Shabah with a 5.7 Merc/Bravo 3 and it hauls.
Not sure what they were rated for, but if the boat can handle it, you are not going to get passed by much. |
Hi Everyone! I am a proud new owner of a 2000 Z222 with a 454 cubic inch, EFI Bravo III engine with captain's choice exhaust. The previous owner removed the engine compartment partitions to increase the air flow and reduce the heat build-up to the engine. Does this sound reasonable or should the partitions be re-installed? Thanks for any help :-)
Missing bow cover and boat cover. Bimini looks aftermarket. Any info? Dealer says that original owner ordered boat with this motor. Was that an option? |
All that I can say is "Holy Crap! A Z202 with a 7.4L and a Bravo III??? Will it even stay in the water? I get a mental picture of just the prop being under the waterline as this blur shoots by..... 1998 202 Shabah 5.0L Alpha 1 |
| All times are GMT. The time now is 06:03 PM. |
