Boat Sputters after I turn it off
Old 07-07-2010, 02:53 AM   #11
SEMIJim's Avatar
SEMIJim is currently offline
My Model: 182 Barchetta
Send SEMIJim:
Default Re: Boat Sputters after I turn it off
Btw: Almost forgot: A lean fuel mixture can also cause an engine to run overly-hot, and result in dieseling.
Jim
  • Old 07-07-2010, 05:08 PM   #12
    Rdrdon's Avatar
    Rdrdon is currently offline
    My Model: Shabah 200 Limited Edition
    My Engine: 5.7L, Alpha One
    Send Rdrdon:
    I've also noticed engines do it if the idle is set high to compensate for a lean condition to prevent stalling when you shift into gear.
    I use Marvels Mystery Oil to help with the low octane gas in our area, seems to help quite a bit. I only use Stabil in the winter, but it couldn't hurt.
    Old 07-10-2010, 01:03 AM   #13
    jchemotti is currently offline
    My Model: 180SE Shabah
    My Engine: 3.0 LX
    Gallery Images: 1
    Send jchemotti:
    I second the use of the Marvel Mystery Oil -- worked well in my Toyota Avalon with 270K miles, too.
    My store was out of it recently and the guy at the marina put K100 into my fill-up. Has anyone had experience with that product, good or bad?
    Jan
    1997 Shabah 180SE
    3.0 LX - Alpha
    A perfect mix ~ my dog, a book, my boat.
    Old 07-15-2010, 04:58 PM   #14
    Jbetschart is currently offline
    My Model: shabah 212z
    My Engine: 350 mercruiser
    Send Jbetschart:
    So I changed out all 8 plugs, switched to 87 octane and poured in so combustion cleaner and it ran great until the end of the afternoon and it happened again.
    I am in Colorado so 5500 elevation.
    I noticed it seems to happen after pulling the tubes at a slower pace for a while.
    I will try adjusting the idle a bit!
    Marvel Mystery Oil is that something that goes in the gas tank or a type of oil when I change it?
    Can you find it at the auto parts or marine?
    Thanks Guys.
    Jeff
    '94 Shabah 212z
    Old 07-15-2010, 07:43 PM   #15
    Rdrdon's Avatar
    Send Rdrdon:
    Marvels is a detergent that can be used in the gas to replace lead & improve octane and can be added to oil to free lifters & clean the crankcase. It's sold in auto parts stores and most department stores.
    How fast is your boat idling and what is the engine temperature when it does this? if allowed to continue it can damage the engine.
    Old 07-18-2010, 02:30 PM   #16
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    I usually use the simple solutions.
    1. Try higher octane gas.
    2. Let the engine idle for a minute to pump cool water though after running at speed.
    3. Shut if off in gear.
    My Mariah
    Old 07-18-2010, 03:14 PM   #17
    Send Jbetschart:
    When we are running full open it runs about 150 for temp. I am not sure what it idles at Ill check next weekend.
    What should it idle at?
    It ran a little better yesterday but but I didn't pull anyone at slow speed for an extended time.
    Jeff
    '94 Shabah 212z
    Old 07-19-2010, 12:42 AM   #18
    42hut is currently offline
    Send 42hut:
    Just a thought, check your timing.
    Old 07-19-2010, 02:30 AM   #19
    Send Jbetschart:
    How do you check the timing?
    Is this the plug gap?
    Jeff
    '94 Shabah 212z
    Old 07-19-2010, 02:32 AM   #20
    Send Jbetschart:
    I changed the plugs like I mentioned and added some combustion cleaner and upped the octane but I am not through that entire tank yet.
    Could it take a few tanks of the cleaner and the higher octane before I notice anything.
    Jeff
    '94 Shabah 212z
    Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    Mariah Shabah 180 won't turn over suddenly? VF143_vet Mercury MerCruiser 5 07-04-2010 06:32 PM
    *SIGH* My turn for electrical problems... stereoman405 Original Mariah Talk 7 05-13-2009 08:33 AM
    Total Threads: 13,324
    There are 415 users
