rpm gauge
Hi,
RPM gauge wont work ,how do you fault find ? thanks lee |
Re: rpm gauge
The first thing to check is the little switch on the back, which selects the # of cylinders. Run it back and forth a few times to clean the contacts and see if that doesn't fix it. Make sure you return it to the correct position... ;)
If that doesn't fix it and the sender is OK, then you might want to consider sending the gauge back to Faria. They have a limited lifetime warranty. For a small shipping fee, they'll refurbish/replace it. Check the support section of their website for details. |
Re: rpm gauge
thank you:wink_thumbup:
| All times are GMT. The time now is 11:19 AM. |
