Cruising RPM???
Old 06-09-2010, 10:47 PM   #11
dieselwiezil is currently offline
My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
Send dieselwiezil:
Default Re: Cruising RPM???
Originally Posted by difran25 View Post
you really think a 21p ss is too much pitch for a 350?
yes it is for mine. I dont remember exactly what my rpms were during my testing. With the 21 aluminum trimmed up, it wouldnt turn more rpms than the lower end of the spec. I removed my drive to inspect the gimble bearing and it all checked out great. I should have everything ready for the water this weekend so I will report my numbers.
2000 Mariah 212 Mercruiser 350
2002 F150 Supercrew
1996 F250 Diesel lots of power goodies.
"Out of everything I have, I still prefer riding MARIAH"
  • Old 06-09-2010, 10:48 PM   #12
    difran25's Avatar
    difran25 is currently offline
    My Model: 1996 Talari 215 5.7L A1
    Gallery Images: 9
    Send difran25:
    now when you say 1p
    = 200 rpm, you mean wot i should be 4200?
    Old 06-10-2010, 12:36 AM   #13
    badold98 is currently offline
    My Model: Z 210 Shabah BR
    My Engine: 5.7 Bravo I
    Send badold98:
    Steroeman405, Thanks very much. This is great info. I will be out at the lake again in two weeks and I will try to get to know the characteristics of my boat a little better. Thanks Again, Badold98.
    Old 06-10-2010, 04:28 PM   #14
    stereoman405's Avatar
    Send stereoman405:
    now when you say 1p
    1P = 200 RPM Change
    So if your boat was WOT @ 4200 RPMs with a 21P, it would increase to 4600 RPMs if you dropped to a 19P. (2 drops in pitch = 400 RPM gain). Inversely if you stepped up to a 23P you would LOSE 400 RPMs and be at 3800 RPMs.
    Keep in mind this is how it should work mathematically, but is all depends on the motor / gear ratio. Your motor has to have the enough horespower / torque to move the weight of your boat at any given speed. If I put a 23P on my 19' Blue Water with its V6, it might not have enough power to get up on plane to ever get to 3800 RPM's. (It would be like starting your car from a dead stop in 4th gear.)
    Also cupping of the prop and diameter plays a big part in this. A higher diameter prop has more surface area which = more friction = less slip = more bite. So a 21P x 13.75 might give you 4400 RPMs @ WOT and a 21P x 14.75 might only give you 4200 RPMs @ WOT AND cause porpoising (bow bounce) because it has too much bite. See isn't this fun how much is involed in this??
    For 350's usually sicking in the 14.25 range is pretty good and I HIGHLY recommend getting SS props unless you are always in the shallows snagging things. SS is so stiff you can plane quicker, cruise at a lower RPM, get more top end all while SAVING GAS. They pretty much pay for themselves.
    I did a side by side test on my dad's 20' Maxum with a v6. Swapped between a 21P x 14.25 SS and a21P x 14.25 aluminum. The results? The boat used to over rev by 500 RPMs and could hit about 50MPH, just by switching to SS it sucked the RPMs down by 450 and ADDED 6 MPH on top end. Better hole shot and cruising speeds. All those RPMs were just wasted $$$$$'s.
    Link to Photos!
    Thank you stereoman405 for this useful post!
    jjk61083 (06-23-2010)
    Old 06-10-2010, 04:29 PM   #15
    Send stereoman405:
    No prob.
    Link to Photos!
    z300 cruising speed/ best fuel economy Aquahead Original Mariah Talk 2 07-13-2009 04:43 PM
    There are 317 users
