At it again!
Old 05-20-2010, 02:53 AM   #11
Boatcrazy is currently offline
My Model: Z302
My Engine: 502 MPI / Bravo III
Gallery Images: 548
Send Boatcrazy:
Default Re: At it again!
Jgreen,
My shop is allowing me to purchase all the parts myself and supply them for the rebuild.
So far my bill with the engine shop is a little over 1K.
Disassemble block
Dip, clean and paint block
Magna-flux block
Line hone
Bore all cylinders to .030 over
Resurface block
Polish crank
Install all bearings
Assemble long block
Complete redo of 088 heads
Parts from KE
509 pistons and rings $800
Cam and lifter kit $1000
Roller rockers $300
Complete gasket set $300
Reprogram ECM $400
PVC, Vinyl and foam approximately $1000
=$4800.00
Under 5K but I guess the powder coated and gauges will take me over that mark but oh well its a B.O.A.T. (break out another thousand).
  • Old 05-20-2010, 04:14 AM   #12
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Coming together nice. How much weight do you think you'll save with the PVC?
    Jay
    Old 05-20-2010, 04:30 AM   #13
    My Model: Z302
    Gallery Images: 548
    Send Boatcrazy:
    I weighed the wood pieces and will weigh the new ones and let you know.
    Old 05-22-2010, 01:24 AM   #14
    95Z212's Avatar
    95Z212 is currently offline
    My Engine: 5.0LX Alpha 1
    Send 95Z212:
    Great job on the boat. Truely amazing job. I'm not sure what I would do with my boat if I ever saw it like that. (Thank god I have a lift!) But after seeing how truely great looking your boat is, even under water, I would have done the same thing (after I made my own river, of tears!!) Truely amazing job.
    1995 Shabah Z212 V8
    2012 CRF 450R
    My location
    Old 05-23-2010, 08:57 PM   #15
    My Model: Z302
    Gallery Images: 548
    Send Boatcrazy:
    Progress this weekend.
    Old 05-26-2010, 02:56 AM   #16
    jgreen's Avatar
    Gallery Images: 2
    Send jgreen:
    Back seat looks good. I sometimes wish I had room for speakers like that, but I have the engine box and two jumpseat/coolers. looking forward to more pics later.
    Jay
    Old 05-26-2010, 03:37 PM   #17
    Hyperryd's Avatar
    Hyperryd is currently offline
    My Model: Shabah 198
    My Engine: 5.7L Alpha
    Send Hyperryd:
    What type of store did you buy the PVC boards from? I have been looking for those, but nobody seems to know what I am talking about.
    I do hope you are planning a whole lot more screws in that speaker box or it its going to rattle apart. Looks great!
    Old 05-26-2010, 03:44 PM   #18
    Hyperryd's Avatar
    Send Hyperryd:
    One other sugestion: I would buy a few extra ice chests. My luck would be after custom fitting them in like that, one would get a crack and I would find out that they don't make them that same shape and size anymore. Maybe that is just my luck, but a couple extra would be good insurance.
    Old 05-26-2010, 08:50 PM   #19
    My Model: Z302
    Gallery Images: 548
    Send Boatcrazy:
    Hyperryd,
    I purchased my PVC board from Farco Plastics out of Jacksonville Florida.
    1" $134
    3/4" $88
    1/2" $67
    In regards to my subwoofer enclosure I plan on gluing it all together with PVC glue and add a SS deck screw every inch. It will be built totally airtight and solid with three separate chambers for each of the 12" Wetsounds subs. I also just purchased off a Craigslist 8 JL Audio 7.7 marine separates for $250 bucks for all of them. Sweet deal and will put them to good use.
    Old 05-27-2010, 01:01 AM   #20
    My Model: Z302
    Gallery Images: 548
    Send Boatcrazy:
    Put the rear section into the boat today to check fitment. Looks like I need to make a few adjustments and then will start disassembling to glue and permanently screw together. I am picking up the foam tomorrow and will hopefully start upholstering this weekend.
    Livorsi gauges should be here next week as well as the rest of the 502 engine parts so the builder can start assembly.
    There are 248 users
