galvonic isolator?
Old 01-15-2010, 08:32 PM   #1
Ederickson is currently offline
My Model: 240Z sport
My Engine: 454 Bravo III
Send Ederickson:
Default galvonic isolator?
Does anyone know if the 1993 Mariah Z240 has a galvanic isolator, or how I might identify such a device? I'm interested in purchasing an aluminum or zinc anode kit and don't know which one to get. My boat is in brakish water for two months and I'm concerned about keeping my outdrive from corrosion (bravo III) Anyone have experience with these electrode devices and if they are effective in preventing corrosion? thanks for any help, liz
  • Old 01-16-2010, 01:35 AM   #2
    Default Re: galvonic isolator?
    hi Liz
    Just as a basic primer on outdrive protection: Anodes act as sacrificial lambs for the outdrive while Cathodes act as a protector of the outdrive against corrosion due to the electrical action between 2 dissimilar metals in water. Now that that is out of the way.....
    This is straight from the Mercury website:
    1. All MerCruiser sterndrives come standard with aluminum sacrificial anodes.
    2. Bravo sterndrives are also equipped with a MerCathode which are optional on Alphas.
    3. Magnesium anodes are suggested for fresh water use ONLY.
    Since you have a Bravo 3 outdrive, it already comes equipped with a Mercathode protection system.
    What is a MerCathode and what does it do?
    The Mercury Precision MerCathode system provides automatic protection against galvanic corrosion. It is a solid-state device that operates off a boat's 12-volt battery and provides protection by impressing a reverse blocking current that stops the destructive flow of galvanic currents. If your power package does not come already equipped with a MerCathode system, Mercury strongly recommends that you install one, particularly if your boat is equipped with a stainless steel propeller or other submerged stainless steel hardware.
    As for your query about a galvanic isolator.....
    What is a galvanic isolator and what does it do?
    The Mercury Precision Galvanic Isolator is a solid-state device that is series connected in line into the boat's green safety grounding lead ahead of all grounding connections on the boat. This device functions as a filter, blocking the flow of destructive low voltage galvanic (DC) currents, but still maintaining the integrity of the safety grounding circuit. A galvanic isolator is only necessary on boats utilizing a shore power connection.
    For those who dont have the Mercathode or other similar cathode protection systems then basically there are 3 main types of Anodes used on outdrives
    Zinc Anodes
    Zinc is the most common material used in saltwater - like boating at the Jersey Shore or the southern end of the Chesapeake Bay. When used in freshwater, Zinc anodes can form a coating after only a few months of use. This coating can stop them from working. It is a good policy to change them regularly, even if they look OK. Remember, if an anode doesn’t wear away it is NOT working!
    NavalloyTM (Aluminum) Anodes*
    The Aluminum alloy used in anodes is very different from normal aluminum. It includes about 5% zinc and a trace of Indium, which prevents the build up of an oxide layer.
    Aluminum alloy anodes provide more protection and last longer than zinc. It will continue to work in freshwater and is safe for use in salt water. Aluminum is the only anode that is safe for all applications. Use these when boating in the Delaware River near Philadelphia, the northern parts of the Chesapeake Bay, or acidic lakes like Lake Wallenpaupack.
    Magnesium Anodes
    Magnesium is the most active metal on the galvanic scale. It can be used in freshwater, but care must be exercised. Magnesium can over-protect aluminum hulls or outdrives in salt or brackish water or even polluted freshwater, causing paint to be lifted with resulting corrosion. Even a few hours immersion can cause severe damage. Many boaters on Cayuga Lake in New York State are switching to magnesium for extra protection.
    Here's a link to an easy to understand article on outdrive corrosion protection & how to choose which anode (or cathode) is right for your application.
    Peters Marine Service Newsletter / Blog: Galvanic Corrosion: What is it and how can we prevent it?
    Hope this helps!
    Ederickson (01-16-2010)
    Old 01-16-2010, 03:26 AM   #3
    Send Ederickson:
    Bravo.... is protected!!!... I so appreciate your time and effort in helping me. Liz
    Old 01-16-2010, 03:49 AM   #4
    hi Liz
    Yes, you should have a Mercathode system already installed on your Bravo 3. Some boats have a Mercathode monitor system installed so that you can check the operation of your Mercathode system at the push of a button. If not, your local marine mechanic can test the Mercathode system also to ensure it is working within the proper operating range. If you dont have a monitor already installed & want some peace of mind, they cost about $60 and about an hour of installation time.
    Unfortunately i've never owned one of these so i've reached the limit of my knowledge on the subject. Hopefully someone else here can kick in a few more details about the Mercathode system and or monitor?
    Best of luck!
    Old 01-16-2010, 03:52 AM   #5
    No problem! That's what we are all here for!!
    Old 01-16-2010, 03:55 AM   #6
    Send Ederickson:
    Talking Re: galvonic isolator?
    thanks once again Mikey...Liz
    Old 01-16-2010, 09:39 AM   #7
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Thanks for this Mike, I kept my boat in salt water for 6 days just recently, and my stainless steel prop came up a dull grey. Normal cleaning wouldnt budge it, but an acid based product easily took off the "corrosion" or "electrolosis" what ever it is called. A local mechanic said it can be caused by the salt water and the chemicals within the stainless prop, but after reading your response I think he may be incorrect.
    Do you have any idea on how difficult it is to install a Mercathode system to an Alpha one?
    Tony
    Perth, Western Australia
    Old 01-16-2010, 02:13 PM   #8
    hi Tony
    No, i really dont know if the Mercathode system can be installed on an Alpha 1 but i suspect anything is possible. If its just the SS prop that showed effects i might consider giving the prop a heavy coat of wax before i put it into salt water again. U might also consider switching your anodes over to aluminum alloy for the extra protection.
    dudders (01-16-2010)
    2nd Battery/Isolator Relay Switch jasfiveo Original Mariah Talk 11 06-04-2009 03:33 AM
    There are 435 users
