-   -   Draft & Beam 216 (http://www.mariahownersclub.com/forum/original-mariah-talk/3483-draft-beam-216-a.html)
216Owner 11-06-2009 06:29 PM
Draft & Beam 216
We've just purchased a 1998 Mariah 216, and are busy enjoying it. On the insurance proposal, we've been asked for the draft and beam. With no manual and no information available from the seller, we are a bit stuck. Can anyone provide this info?
WetWilly 11-07-2009 07:33 AM
Re: Draft & Beam 216
Hi 216Owner and welcome to the forum!
Let's see if we can satisfy your insurance company..........
The '98 brochure list the following:
1) Your beam is 102"
2) I believe they want the draft of the boat only and that would be 19" (outdrive in the up position), but in case they want to know what it is with the outdrive in the down position, it's 36"
3) Here's a little more info for you - your 216 is 21' long (LOA), has a 60gal fuel tank and weighs around 3175lbs
If there is anything else you require, just ask away :wink_thumbup:
216Owner 11-07-2009 11:51 AM
Many thanks - much appreciated.
