Stereo Replacement/location
Old 03-18-2010, 01:19 AM   #21
Weezer is currently offline
Status: Gold Contributor
My Model: 1993 Barchetta 4.3LX Alpha One
Default Re: Stereo Replacement/location
Ok, I appreciate the info. But, I still have a few questions. 1. Does anybody know where exactly the rear speakers should be mounted? 2. How much clearance for speakers do you have (Barchetta model)? 3. How do you remove the side panels? I can only find the screws on the upper part. 4. If I can not remove the panels, what is the easiest way to cut the holes without making a horrible mess. Fiberglass dust sucks.
If anybody has any words of wisdom, I sure would appreciate it. I don't mean to be an ignoramus, I just do not want to mess up my boat. Please help!
  • Old 03-18-2010, 02:29 AM   #22
    Paul F is currently offline
    Gallery Images: 4
    I have the reach bench seat. I removed the panels on each side of the bench (very easy to do) and took them to a stereo shop and had them cut the hole and mount the speakers.
    I didn't want to take a chance of screwing up.....
    All I had to do is reinstall the panels and hook up the speakers to the wiring already in place.
    Old 04-15-2010, 05:07 AM   #23
    kevo is currently offline
    My Model: 180 Shabah
    Dredd - What did you use to cut the metal bracket out where the knobs went through?
    Old 04-15-2010, 06:11 AM   #24
    Status: Super Moderator
    Hi kevo, have you got a Dremel? it's my favorite tool for modifying stereo openings with a cut-off disc.
    If you've got one then use masking tape to cover the opening and draw your modifications on the tape and just go slow while following the lines. You can deburr the edges with the wire or stone wheel or fine sand paper.
    Old 04-15-2010, 06:04 PM   #25
    Dredd is currently offline
    My Model: MX-19 - Sold
    It was actually all plastic and I used a 4" hand grinder :| then cleaned up the edges on a bench grinder. It was a little nerve racking but it came out good. Ideally I would have used a Dremel like WW suggested.
    Old 04-16-2010, 02:14 AM   #26
    Thanks dredd and wetwilly.. Good info. i have an old knob stereo that I'm so tired of and want out.. This spring I'm changing it all head unit and speakers. If you guys come across a good deal please post or email me..
    Old 05-13-2010, 01:48 AM   #27
    depman160 is currently offline
    My Model: 2000Z
    My Engine: 5.0L Merc Alpha 1
    Just an update....the stereo I bought was installed very easily. Sadly I wasn't able to get installation pics, but my buddy had it done in about an hour.
    He had to enlarge the opening i the dash to fit the new head unit and surrounding weather protector thing in, but other than that, it was quick, painless and SOUNDS GREAT!!!!
    If only it could be summer all year long!
    Z192 Factory Console Plate Replacement/Switch Location? jkboliphant Original Mariah Talk 7 09-23-2010 12:55 PM
    Buzzer location? jkboliphant Original Mariah Talk 3 04-26-2009 01:43 PM
    Switch function and location jkboliphant Original Mariah Talk 0 04-19-2009 06:15 PM
    Speedomter location dmg5606 Original Mariah Talk 3 08-27-2008 01:35 AM
    Fuel filter location on a 2000 7.4 MPI? Jeff Barnett Mercury MerCruiser 6 11-20-2007 10:15 PM
    Total Members: 6,466
    Total Threads: 5,950
    There are 27 users
