-   -   New Owner of z210 Talari...Power hatch (http://www.mariahownersclub.com/forum/original-mariah-talk/3191-new-owner-z210-talari-power-hatch.html)
oncman 08-13-2009 02:14 AM
Hello All. Just bought a 95 z210 Talari. The pistons that are supposed to raise the sundeck have been removed. Any idea how to repairs these, or where I can buy two struts to hold the sundeck open (similar to what you have with a car's hood). Also the windshield defoger does not appear to function. Any idea how to fix? Thanks!:confused:
ShabahZ280 08-15-2009 12:41 PM
Re: New Owner of z210 Talari...Power hatch
welcome to the board oncman! this is a pretty common issue, we've got some info in the Mariah Parts List at the top of this forum, and if you do a search for "hatch" "actuator" or "lift" you'll probably find all the info you need!
as far as the window defogger, check the fuse block, then check the connection at the actual switch. mariah's electric connections are notorious for corrosion, sometimes all it takes is a little cleaning of the contacts to get things working again. if not, let us know and we'll try and help you fix the defogger.
WetWilly 08-15-2009 09:28 PM
Ahoy oncman and welcome to the club!
Check out this thread for ideas for your hatch, click here.
