-   -   Electric fuel pump for carbed 350 (http://www.mariahownersclub.com/forum/original-mariah-talk/3016-electric-fuel-pump-carbed-350-a.html)
Hyperryd 07-20-2009 05:45 PM
I want to block off my mechanical fuel pump and add an inline electric fuel pump next to the tank. If I use a low pressure pump, do I need a regulator? What else would I need to do? Has anyone here done this? I have the two barrel carbed 350 in my '97 Shabah.
ShabahZ280 07-21-2009 03:43 PM
Re: Electric fuel pump for carbed 350
What's the purpose of an electric fuel pump on a carb engine? I've never heard of that, Is it a performance thing?
GrayDog 07-24-2009 03:03 PM
When carbed engines are shut down, the heat from the engine tends to boil off the fuel in the fuel line and carb causing hot restart problems. By switching to a regulated electric pump, you don't have to wait for the mechanical pump to build up pressure.
As far as a regulator is concerned, I (old school mechanic of 15 yrs) would recommend you add a regulator in line to insure you don't overpressure the needle in the carb.
In the process of converting, route the mechanical pump lines to themselves but leave enough hose length so you can reattach in the original configuration if your electric pump dies in the middle of the lake. Nothing worse than having to get towed in. :mad:
95Z212 07-25-2009 03:27 AM
Yea, I know how that feeling is, with the Gayliner. The thing blew up on my birthday. Ya wanna try and really get attention, have smoke come out of the blower holes, bilge hole, ect. Boaters surround you like no tomarrow :rolling_laugh: Sold that POS for $500.
midwest mariah 07-26-2009 12:49 AM
been there done that! Gayliner Crapi:punch_out: learned my lesson early in life!!
