Tube shape filter ? SAE 1171
Old 07-19-2009, 08:29 PM   #1
Gallery Images: 2
Send Douglas Alderman:
Default Tube shape filter ? SAE 1171
What is the tube shape filter next to the fuel pump do on my 5.0 2005 Merc. Shaped is 1 1/2 by 5 in. with two wire on top. fuel line is attached to it.
  • Old 07-20-2009, 09:50 AM   #2
    Default Re: Tube shape filter ? SAE 1171
    Hi Douglas,
    Picture's worth a thousand...
    Anyway, it sounds like "that's" your electric fuel pump. Is your motor fuel injected or carbed?
    WetWily
    Old 07-20-2009, 09:53 PM   #3
    Gallery Images: 2
    5.0 Carb. I will try and take picture of it.
    Old 07-23-2009, 11:05 PM   #4
    Gallery Images: 2
    0723091043a[1].jpg] This is the filter in Question!
    Old 07-25-2009, 12:13 AM   #5
    Gallery Images: 2
    Question Re: Tube shape filter ? SAE 1171
    Is that an electric fuel pump?
    Old 07-25-2009, 02:08 AM   #6
    It sure looks like it. This is from mercruiserparts.com it's on the diagram for the 5.0L engine, and it's listed as a "fuel pump assembly"
    What's odd though, the SAE J1171 as listed on the sticker is a part number for an alternator.
    Old 07-27-2009, 09:44 AM   #7
    Hi Guys,
    SAE 1171 is a NMMA Certification for the part and not the part number. I believe it referrers to "External Ignition Protection of Marine Electrical Devices" so all of our electrical parts should be SAE 1171 certified and they maybe labeled as so.
    Douglas, I remember reading that some of the Mercruiser motors use a "booster" pump, so if you don't have a mechanical pump, it's your primary, but if there is a mechanical pump, it's your "booster".
    Fuel Filter Replacement? MAJIC Mercury MerCruiser 0 05-01-2009 12:34 PM
    oil filter and gas filter wssb11 General Maintenance 3 02-17-2009 02:04 PM
    Fuel filter location on a 2000 7.4 MPI? Jeff Barnett Mercury MerCruiser 6 11-20-2007 09:15 PM
    There are 237 users
