Now A Silver Member Need Help!!!
Old 07-09-2009, 12:17 AM   #1
llcelebrity is currently offline
Send llcelebrity:
Default Now A Silver Member Need Help!!!
Found a wire schematic for like 20 of the 5 thousand wires........what do i do now i need a wire diagram of all of the massive wire clusters at the back of my dash HELP HELP alot of my switches are not working and i am soooo lost
  • Old 07-09-2009, 07:48 AM   #2
    Default Re: Now A Silver Member Need Help!!!
    Hi llcelebrity,
    Can you list the gauges and switches that don't work? the switches should be labeled or have icons on them to indicate what they control.
    If you have a digital camera, can you take some pictures of the wiring, it would be easier than having you list all the wires by color code.
    If you need assistance with attaching pics to your post, click here and this tutorial will explain it.
    There is an older schematic that might still work for your dash gauges as Mariah probibly used the same colored wire for all the boat gauges, click here.
    Good luck,
    Quick Silver Shifter dmg5606 Original Mariah Talk 9 06-15-2012 04:08 AM
    upgrade from silver to gold rooperdan Introductions 2 02-22-2009 09:42 PM
    There are 387 users
