accy switches
:confused:Hey Folks!O.k.,so I've pretty much figured out everything on my Mariah.I do,however,have questions regarding the five accy switches on the dash.Starting from left to right,the first one powers the radio/antenna and the exhaust switch.The next four do'nt seem to operate anything.With those off or on while running,everything else works.What do they operate,if anything,and do they need to be on while running?Are they switches for aftermarket items?Thank you for any input.
Re: accy switches
You know, I have a couple that do nothing as well........next trip out, I am going to check the back of them and "try":shakehead: to follow the wires.
Re: accy switches
Chances are they're for aux items, and they're wired into your main power, but don't have anything hooked up. If you can get a look behind the switches, you'll probably see they have an open terminal on the back of the switches. That's how mine were. I wired my power amp for the stereo into one of them. I think i've still got two open.
Can you post a pic of your switches? 5 acc switches sounds a little high. This way we can try and help you figure out what's up here. |
Re: accy switches
Thanks for the responses.Yes,I"ll get a pic of the dash.I'm pretty shure I counted 5- 3 on the left side of the steering column and 2 on the right.
| All times are GMT. The time now is 03:48 PM. |
