99 jubilee 244 wire schematic?????
Old 07-08-2009, 05:50 AM   #1
llcelebrity is currently offline
Send llcelebrity:
Default 99 jubilee 244 wire schematic?????
just bought this boat some of the dash switches dont work........took the whole dash out HELP GUYS I NEED YOU ASAP
  • Old 07-08-2009, 08:12 AM   #2
    Default Re: 99 jubilee wire schematics ????
    Hi llcelebrity,
    "HELP GUYS I NEED YOU" doesn't really tell me how to help you and I have a really twisted imagination so we won't go there...
    Anyway, I recommend you become a contributing member first (click here) so you can access the '99 wiring diagram on file. After which, if you still need assistance, let us know what we can do for you.....
    WierdWilly
    Old 07-08-2009, 04:49 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: 99 jubilee 244 wire schematic?????
    Welcome to the club!
    If you become a contributing member to the site, you will gain access to all the manuals, brochures, wiring diagrams and service manuals. Simply click on the Donate link in the banner at the top of the page.
    My Mariah
    Old 07-08-2009, 04:53 PM   #4
    Send llcelebrity:
    well some of my dash switches are not working some of my gaudes are not working........and some of them that are not working now were working before I took out the dash to paint. Im thinking I needed a wire diagram to start out....I would be glad to donate if I knew there was a wire diagram for my exact boat on the site..... let me know what to do from here..
    Old 07-08-2009, 04:58 PM   #5
    Send llcelebrity:
    what level do I need to donate to access a wire diagram for my boat.....
    Old 07-09-2009, 07:17 AM   #6
    Hi llcelebrity, click here and select the lever you would like and once your level is approved, we'll get started on getting your dash working ASAP.
    BTW, since you dash is out, hopefully the battery is disconnected, if not, please do so before we begin, thanks
    Old 07-09-2009, 08:22 PM   #7
    Send llcelebrity:
    did alot with with the battery connected....oops!!! any fuses i could have blown that may be my problem????there are four or five under the dash already checked they are ok.........a smaill story to how i got here.....originally the power light that raises wasnt working...thats it... then i took the dash out and painted it and put the dash back in.... then the hatch wasnt working and the light that raises in the back....... we took out every gauge and was sure we wrote down where the wires originally went and put them back but now im thinking maybe not....... now 90 percent of the switches dont work and the depth gauge and trim up and down gauge from what i can tell out of water.......im so lost where do i start im far from an electrician
    Old 07-11-2009, 05:36 AM   #8
    Send llcelebrity:
    Ok found a few fuses that were blown and replaced them....put the dash back in....and lost my keys!!!!!!! the power hatch works and the power seat and thats it....dont know if I have to have the key on for the other switches and gauges to work or they still dont work not sure yet......... there is two sets of wires that i need some help on....I have a red and green and grey wires coming right from the tripometer or hour meter whatever it is...... the one you can push the button and it resets back to 0000....not sure what these 3 wires go to....also there is a thicker back tube with 4 or 5 TINY wires coming out of it.....red green brown white and another color i cant remember.....what are these to.........they kinda look like the same type of wires that are in the grey tube with the white plug going into the compass they are some of the same colors and are tiny wires....
    One more question there is a black plastic thing on the very back of the boat with a little wheel that turns when in the water looks like a gear with big teeth what is this......???
    Old 07-12-2009, 01:21 PM   #9
    the thicker black tube with the 5 connectors that attaches to the trip odometer (with reset button, 0000) connects to the small paddlewheel transducer on the back of your boat. this apparently is supposed to use water flow to track how far you've gone. However i've never been able to figure out exactly how it works. It's never been accurate at all!
    Old 07-12-2009, 02:11 PM   #10
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Water turns the little wheel, which has a tiny magnet, or tiny magnets, that pass by a sensor in the body of the device that counts the pulses.
    I don't know about the speedometer on Mariahs, but the Raymarine knotmeter on our sailboat has a calibration mode. Our knotmeter is pretty accurate--usually within 0.2 knots or so of the GPS' SOG (speed over ground) reading, except where there's a current.
    I've no idea how accurate the speedometer on our Barchetta is, but I suspect its reading bears no relationship to reality
    Jim
    Unknown Wire 2000Z272 Mercury MerCruiser 9 06-21-2009 12:42 AM
    Wanted: Electrical Wire Diagram (99 Jubilee) 214 Douglas Alderman Mariah Parts For Sale & Wanted 3 04-13-2008 05:22 AM
    wiring schematic dieselwiezil Original Mariah Talk 1 04-07-2008 03:04 PM
    Need Wiring Schematic for 98 Z255 chadh Introductions 1 03-10-2008 03:30 PM
    There are 238 users
