-   -   trim gage (http://www.mariahownersclub.com/forum/original-mariah-talk/2767-trim-gage.html)
difran25 06-17-2009 01:02 AM
trim gage
my trim gage does not work. whats wrong. i have to do it by sound right now. whats involved in the fix?
WetWilly 06-17-2009 07:14 AM
Re: trim gage
1 Attachment(s)
Hi difran25, there are three things that could cause your problem (gauge, wiring, Trim Position Sender) so use the troubleshooter attached to bottom of this post
If the Trim gauge is broken, send it to Faria for a warranty repair, click here.
If the Trim Position Sender on the outdrive is bad, it will require replacement of both the Trim limit and Trim Position sensors and possibly removal of the outdrive to access the wiring.
Good luck,
