-   -   power stern light (http://www.mariahownersclub.com/forum/original-mariah-talk/2648-power-stern-light.html)
rusty 06-02-2009 08:56 PM
power stern light
Hey folks,Hope all is well in Mariah land.I have a question regarding the motorized telescoping stern light.Mine is inoperative on my 98 shabah Z210.Test light shows fire going to it.This may be as simple as which switch on the dash operates it?However,I have tried them all.Input/experience on this would be appreciated.By the way,which switch does operate it?
ShabahZ280 06-02-2009 11:37 PM
Re: power stern light
The switch that says "Nav" and "Anchor" should operate it. To the best of my knowledge, they still manufacture this, it's made by Innovative Lighting Products. They make an LED version which uses less juice too! :wink_thumbup:
jimshabbah 06-03-2009 03:09 AM
I also had to replace the power stern light on my '97 Z222. The above recommendation is right-on. That is who I bought my replacement from and it was an easy swap. I replaced 3 years ago and haven't had a problem.
rusty 06-03-2009 12:43 PM
Hey thanks for the input.Looks like I may have to replace it.I have the original brochure in my owners manual,looked them up,and its still available.:wink_thumbup:
ckgreenman 06-08-2009 07:47 PM
Does anyone know if you can buy just the lens? A friend of mine is getting ready to buy a 2000 Shabah Z222 and the lens on the stern light is missing.
Thanks.
jimshabbah 06-09-2009 05:13 PM
I don't know about the 2000 model, but i know on my '97 you could not just change the lens. I would call and talk to someone at the following; http://www.innovativelight.com/. There were very helpful to me a couple years back on my swap from the old style to the new.
ckgreenman 06-10-2009 02:51 AM
Ok thanks. I sent them a message.
Tomroth 10-03-2021 04:57 PM
Does anyone know if Inovation Lighting or ANY company that sells a power stern light, such as the one that's mounted in my '99 Z222 Shabah? Is conversion over to a external mount my only choice? Probably so...
mikeyt 10-04-2021 01:20 AM
Innovation stopped making that power light a few years ago. No other option other than trying to repair the one you have, find a used replacement or switch to an external mount antenna.
Sparks&Stripes 10-04-2021 11:35 AM
Mine was not working when I bought my boat in the spring. I cleaned each wire end on the light and also cleaned all the terminals behind the radio on the fuse block and installed a new fuse. There was white corrosion on everything. The power light is working again with no issue. Try that first you might get lucky like I did, otherwise it will have to be switched to a manual one.
