sticky neutral button on volvo penta
I have a new to me 2001 Diablo with the 4.3l Volvo Penta. The Neutral button on the control unit sticks when I start the boat. So far after repeated jiggling and attempts I have been able to eventually get it into gear. I am nervous every time we launch that this time it won't work. Is there any easy fix or way to lube the button??
Thanks for the help:confused: |
Re: sticky neutral button on volvo penta
I will hopefully see your question answered... I have pulled the entire panel while on the water, found nothing wrong, put it back together and worked fine for 3 months (12-14 days on the water).
than it got stuck again... :shakehead: |
This time I sprayed some silicon on everything that moves...:wink_thumbup: |
Any fixes to this?
The switch is not hard to get at if you remove the throttle control from its panel.
Once removed the switch should be a readily replaceable part from Volvo or tracked down by an electronics supplier. If you ever find yourself in a real bind, you can remove the wires from the switch and connect them together to bypass the switch till you get back and can have it replaced. Dont use as a permanent solution however as it could create a dangerous situation with a boat starting with the prop engaged. |
| All times are GMT. The time now is 05:06 AM. |
