hello every body great site i need just a liilte help
Old 05-25-2009, 03:47 PM   #1
mpotenciano is currently offline
My Model: mariah 2001 diablo
Send mpotenciano:
Default hello every body great site i need just a liilte help
helo every body this site is great thing but i need a lillte help i took my boat out and ran it for 30 minutes i had left atowel over the bielge pump and when i was park i remeber and took it out i had no power to start my motor back up i check every thing and found a 7.5 fuse blown out so i replace it with a 25 amp fuse thats all i had and still it would not start can any one help please i new at this forum as well i dont know how to naviagate ye t but i will i have a 2001 marah boat inboard and out boad thank you for this long message
  • Old 05-25-2009, 11:58 PM   #2
    Default Re: hello every body great site i need just a liilte help
    Hi mpotenciano and welcome to the club!
    OK, I'm curious as to how you got a towel over the bilge pump...
    We'll need a little bit more information to assist you so let's start with the basics:
    Does your motor crank at all?
    If not, is your battery is fully charged?
    Have you checked and cleaned your battery terminals?
    If you have a dual battery switch, is the switch in the correct position?
    Does the motor crank but won't start?
    Is the shifter in the neutral position? (wiggle the shifter back and forth in case your neutral switch is a little out of alignment)
    Is the Kill Switch in the run position?
    Is the master circuit breaker tripped? (Big red button located on top on the engine towards the rear)?
    you know what they say: If you don't know what it is, eliminate what it isn't and what's left is your problem....
    Don't forget to replace that 25 amp fuse with a 7.5 amp fuse to be safe.
    Good luck and let us know what you find,
    Throttle Body Restriction?? Jeff Barnett Mercury MerCruiser 13 08-31-2011 02:20 PM
    Great site beck812 Introductions 2 05-05-2009 12:39 AM
    Great day out on the lake! bpfirrman Trips, Travels, and Meet Ups 2 07-20-2008 03:48 PM
    What a great find!! rustyshakelford Introductions 4 06-30-2008 01:25 PM
    Great idea 94 Talari Introductions 2 07-19-2007 01:53 AM
    There are 303 users
