-   -   1995 272 barchetta (http://www.mariahownersclub.com/forum/original-mariah-talk/2557-1995-272-barchetta.html)
karmann 05-19-2009 03:33 AM
1995 272 barchetta
Hello
My water temp gauge was removed from radio panel, & the digital read out above the depth guage don't work?
Where do you start testing?
thanks
WetWilly 05-19-2009 06:09 AM
Re: 1995 272 barchetta
Hi karmann,
If your missing the temp assembly from the radio panel, I'm afraid that was an in-house product so locating a replacement will be extremely rare. As for the Digital Display, I assume your referring to the red display located near the top center of your dash. If that's the case, it called the Mariah Digital Information Center or Mark 8. I recommend trying to contacting rjobe, he has the most expertise with this display and the water/air temp display too.
When you get your center display working, consider becoming a contributing member, if you do, you'll have access to the Mark 8 user's manual as well as a lot more documentation, brochures and manuals for your Mariah! So if you're interested, click here to see what each level offers. I strongly recommend it, it's the best money you can invest to help insure you keep your Barchetta running in top form!
Good luck,
