Need help
Hi guys need some help. Just changed my impeller and started it today for the first time this year. My alarm will not shut off . The water temp is good 175. Is there a alarm for the lower oil unit? I changed the oil in the lower unit I am sure that it is full. Is the alarm for anything else but water temp?
Thanks Mark:( |
Re: Need help
Yep, there's an alarm for the lower unit oil. The sensor is built in the plastic reservoir mounted on the engine. That was actually the cause of my alarm fiasco last year. The alarm would beep every 3 seconds. It was a $50 part, but cost over $700 in diagnostic fees and return service visits to find out the problem.
The alarm system usually has 3 sensors. 1. Engine Oil Pressure 2. Water Temp 3. Lower Unit Oil If you wanted to test things yourself, the sensors are usually tan colored wires with a blue stripe. |
Re: Need help
Well I feel like a idiot. The drive reservoir will drain out when you pull the lower unit. So I put in the gear lube up to the full line on the reservoir and started it up NO ALARM. So the boat goes into the water on Saturday.:)
Re: Need help
No worries Mark, we all make these kind of mistakes. It's a learning experience, right? :yes_grin:
Re: Need help
Hi Chris, I have had the exact same problem with my motor.
I got it back from the mechanic and it was beeping at all sorts of different revs and speeds. I checked all the oils and they were fine. You mentioned the lower unit oil - is that the one reservoir that is seperate to the motor? If you could perhaps supply some photos of which one it is I would greatly appreciate it. |
Re: Need help
I will post you a pic in the morn. But the reservoir is in front of the motor.It will say drive oil reservoir. good luck
Re: Need help
Great Mark, thanks for the fast reply. That alarm is a real pain, especially when you just know there shouldnt be anything wrong. :wink_thumbup:
| All times are GMT. The time now is 04:38 PM. |
