95 272 Barchetta Horns?
Hello
Is there anywhere to get a set of the original AFI horns for a 95 z272 barchetta? thanks |
Re: 95 272 Barchetta Horns?
Hi karmann, if you have the horn's model number, try contacting AFI and see if it's still available and where to get it. AFI's number - 707 - 226 - 9600.
WetWilly |
Hello Wet Willie
Stock AFI's are discontinued, However they have a set of air trumpet horns that are a exact fit replacement, with only having to mtg. the air compressor for $275.00 complete. I ordered them from Amazon.com W/ free shipping. thanks for the phone # and info. |
Hi karmann, glad to hear you found a solution for your horn! Air horns huh... just be careful when you hit the button or you might find your Mariah listing to port real quick! :closed_chuckle: WetWilly |
Hello All
Received the updated AFI air horns today, they sound awesome. I think they might work as a bow thruster haha. thanks again |
Where is the horn located on a 1995 Mariah barchetta?
Press the 'horn' button and you will find it. If that doesn't work then it is usually up under the dash mounted against the hull. Given your two questions to date and that you are a 'silver' contributor, you might want to read the owners manual that you have access to here on this site.
Fellow 272 Barchetta owner here. Interested to see how your upgrade turns out!
| All times are GMT. The time now is 01:05 AM. |
