Seat lift mechanism?
Old 04-07-2009, 06:34 AM   #1
anthonybradley is currently offline
My Model: Z216 '97 Merc 5.7l Alpha one.
Send anthonybradley:
Default Seat lift mechanism?
Hi all,
The rear seat on my Z216 that hinges up is a PITA the lift, for some reason it doesnt have the electric lift even though its a 'Z' spec and alot of other Mariahs seems to have it.
At the very least I want to add some gas struts to make it easier to lift, but am undecided as to where to mount them, I guess they will have to go on each side of the engine bay.
Does anyone have any pics please showing their configuration, so I can compare and gain inspriation?
Anthony
  • Old 04-07-2009, 11:24 AM   #2
    Default Re: Seat lift mechanism?
    Mine has gas struts on both sides, I will try and take a pic for you next time I uncover the boat.
    Old 04-07-2009, 09:34 PM   #3
    That would be great thanks, if you see any manufacturer / model markings on the gas struts that would be most useful in trying to figure out what specification / pressure gas struts are required.
    Many thanks!
    Anthony
    Old 04-07-2009, 11:24 PM   #4
    I have the part numbers and manufacturer listed for mine on the Mariah Parts List
    Hope this helps.
    Old 04-08-2009, 08:58 AM   #5
    Many thanks!
    Anthony
    HI guys,
    Don't know if this helps, but here are a few pics of our gas strut setup. The struts are SPD 120lbs units due to the size of the Sunpad and the shallow leverage angle.
    This setup takes a little effort to initially open the hatch but after that it's a lot easier and a little past half way, the pad goes up by itself and stays there. I prefer it this way, even though there are two retaining straps, I wouldn't want the pad to pop open while under way or while towing!
    If memory serves me, (but probibly not) I seem to remember see something about someone loosing their pad while towing because it flew open.....
    Old 05-15-2009, 02:00 PM   #6
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    WW, do you know what length (open an closed) those gas shocks are?
    Old 05-15-2009, 07:34 PM   #7
    Hi blockp,
    They're 20" open and 12" closed.
    Our setup only requires a 6 1/4" stroke so ours is 13 3/4" closed.
    Here is a list of SPI's shocks with lift force as well as open and closed lengths. Click here and scroll down the page.
    Old 10-25-2009, 12:47 PM   #8
    edward cossey's Avatar
    edward cossey is currently offline
    Status: Ed Cossey ( sonny boy )
    My Model: 1998 Z252 Shabah Mercr
    My Engine: 7.4L Bravo 111"
    Gallery Images: 4
    Send edward cossey:
    hi guys
    sorry ive not been online for a while ive been on vacation for a month playing with my mariah, i have tried to get my eletric hatch working but have now given up the idea and replaced the gas struts with new ones , although it works fine i still would have prefered to keep the boat as original . the old hatch motor was disconected when i bought the boat i stipped it down and found it was seized i freed it up and got it working off the battery but i cannot figure the wiring set up as the connector has two wires , one for the up and one for the down, i cant see how the earth connection runs , would it connect directly to the battery earth terminal or connect to the wiring loom somewere. any ideas
    Ed Cossey
    Old 10-25-2009, 03:06 PM   #9
    Hi Ed and welcome back!
    The wiring for the hatch lift should be the same as the driver seat forward/aft switch. Both the Positive and Negative wires from the lift run back to the 6 or 10 tab switch center contacts. Power and ground are attached to the upper and in a reverse pattern on the lower contacts of the switch.
    To get a better idea, click on the attached pictures.
    Good luck,
    Old 10-25-2009, 09:34 PM   #10
    Gallery Images: 4
    Send edward cossey:
    thanks willy
    im not back to florida till march 2010 and will try and check the wiring. have you got any idea howthe hatch lift fixes to the deck of the boat as the fixing bracket is missing the hatch fixing bracket is still there .
    all the best
    Ed
    Help! Need info on Engine Hatch Lift - Z302 milemarker60 Original Mariah Talk 6 07-13-2022 10:58 AM
    jubilee hydraulic hatch lift Gunner Projects 0 06-15-2008 07:49 PM
    Battery Operated Hatch - Release Mechanism EBO Original Mariah Talk 10 02-03-2008 12:27 AM
    96 talari Z240 Engine Hatch Lift Help WetWilly Original Mariah Talk 8 10-02-2007 12:30 PM
    New seat for my son 215Talari Chit Chat/Off-Topic 10 08-26-2007 03:29 PM
    There are 476 users
