Seat lift mechanism?
Old 08-25-2010, 12:34 AM   #11
jchemotti is currently offline
My Model: 180SE Shabah
My Engine: 3.0 LX
Gallery Images: 1
Send jchemotti:
Default Re: Seat lift mechanism?
I'm so glad that I found this thread. I have a 97 Shabah 180, and have those struts which lift the sunpad.
Questions:
1. Is there a switch on the instrument panel that is supposed to lift those struts?
We've had the boat for 2 months, have been lifting it by hand, which can be difficult at times.
(There is one switch on the dash that does nothing when pressed))
2. One of the struts is bent at almost a right angle, due to a friend of my daughter trying to maneuver the bimini with convertible top attached, into the storage area - I'm sure he caught the strut and pushed down on it, causing the bend. (Kids these days...)
Thanks in advance for your response.
Jan
Jan
1997 Shabah 180SE
3.0 LX - Alpha
A perfect mix ~ my dog, a book, my boat.
  • Old 09-01-2010, 12:21 AM   #12
    Hi Jan, from what you descried in #2, you have gas shocks (very worn out and now bent) and not a powered lift system so it's most likely that there will not be a specific switch for the SunPad unless there was one previously installed then removed.
    The non operating switch is probably a two position switch for any additional accessories you might want to add to your Mariah so you can turn them on or off, a lift switch will have three positions.
    Look closely at your existing shocks for any printing or label indicating the pressure rating, then try to measure the shocks total length open and closed so you can purchase proper replacements to help with the opening of the SunPad.
    Good luck,
    Thank you WetWilly for this useful post!
    jchemotti (09-02-2010)
    Old 07-26-2011, 10:16 PM   #13
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Does anyone know what pressure the sunpad lift arms should be on a Z210. The ones on mine are 20 lb and do not hold the sunpad up. I'm sure a previous owner must have replace the orginals with the wrong ones or it never had them and he installled ones that are to light.
    Old 07-30-2011, 01:56 PM   #14
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    I picked up a pair of 60 lb (20" open, 12" closed) gas struts from NAPA auto parts with the agreement that I could exchange them for heavier ones if needed. I installed them and they worked fine. My leverage angle is not as shallow as in WetWilly's picture so the 60's work fine for me.
    Old 06-19-2017, 10:09 AM   #15
    rgeissmann is currently offline
    My Model: 2200 ZC
    My Engine: MCM 5.7LH/V8
    Send rgeissmann:
    Hi Ed and welcome back!
    The wiring for the hatch lift should be the same as the driver seat forward/aft switch. Both the Positive and Negative wires from the lift run back to the 6 or 10 tab switch center contacts. Power and ground are attached to the upper and in a reverse pattern on the lower contacts of the switch.
    To get a better idea, click on the attached pictures.
    Good luck,
    Hi Willy !
    For some reason my hatch lift as well as the driver seat fwd/aft switch stopped working suddenly at the same time yesterday. Would you happen to know if there is a fuse i need to change ?
    Thx for your help
    Help! Need info on Engine Hatch Lift - Z302 milemarker60 Original Mariah Talk 6 07-13-2022 10:58 AM
    jubilee hydraulic hatch lift Gunner Projects 0 06-15-2008 07:49 PM
    Battery Operated Hatch - Release Mechanism EBO Original Mariah Talk 10 02-03-2008 12:27 AM
    96 talari Z240 Engine Hatch Lift Help WetWilly Original Mariah Talk 8 10-02-2007 12:30 PM
    New seat for my son 215Talari Chit Chat/Off-Topic 10 08-26-2007 03:29 PM
    There are 315 users
