Re: Factory Radio Trim Faceplate
True, but what's $50 in the life of a Mariah (or ANY boat owner?!) :wink_thumbup:
1 Attachment(s)
Installed!
The auxilliary cigarette lighter broke, so I need to go get a replacement. :shakehead: Also waiting for my iPod dock. Pretty cool, check it out: http://www.athome-atsea.com/dock.htm :wink_thumbup: |
Thanks for the link. I have a spot that has bothered me for 2yrs, I can use the rosewood to cover it.:wink_thumbup: |
1 Attachment(s)
Here is the drawing from my machine shop.
A few notes: 1. The radio (Sony CDX-H905iP) is a bit larger than "normal" radios, so your access hole dimensions may need to be adjusted; 2. The second auxilliary power port (lower right) has two screw holes that will need to be increased in diameter. I originally copied the holes from the existing outlet, but it was designed for self-tapping screws. Hard to do into aluminum, plus I wanted machine screws with nylon lock nuts. 3. The site wouldn't accept the AutoCad DXF format, so I renamed the drawing to a .TXT file. Save and rename, and you should be set if you have AutoCad. Enjoy! |
I have a good friend who owns a machine shop and business is slow right now. So if anyone is interested in this I can hit him up with it and see what it would cost. I imagine if he were to run a few at a time it could get the price down. Also if anyone has any other ideas that a CNC lathe and mill could make happen let me know.
3 Attachment(s)
Finished...updated and finished the electronics.
Installed an iPod dock and another power point. woohoo. Also installed the waterproof remote for the radio. Now I can float, drink and manage my tunes! :wink_thumbup: |
4 Attachment(s)
Also buffed and waxed the beast...amazing how bad maroon/red fades in the sun... :(
Compare the remote contraol pics, what a difference! :D |
| All times are GMT. The time now is 05:04 PM. |
