Dashes cracked Help!!!!
Old 09-03-2008, 03:35 PM   #1
tet68's Avatar
tet68 is currently offline
My Model: Mariah Z202 1999 Mercr
Send tet68:
Default Dashes cracked Help!!!!
I read on this forum that the dash I need is made in-house , the woodgrain one ,
( mariah Z202 1999 ) now mine is cracked , is there any way too get one????
I only need the curved woodgrain part
Mine looks like it is used in the new models after 2001???
Dashes:
-Dashes, pre-97 (large 3 sided square ones)
Paramount Plastics, Inc.
Elkhart, IN
www.paramountplastics.com
(I have confirmed they only produced the dashes up to 1996-97, when they "stopped doing business with Mariah")
-Dashes, post-97 (curved molded ones, with woodgrain finish) were created in-house at Mariah with a vacuum formed plastic mold
  • Old 09-03-2008, 03:46 PM   #2
    NOPE, unfortunately there's no place you can get a replacement.... you can only get it repaired.... And let me be the first to tell you it's not easy, and one mistake can ruin your whole dash. It was a winter project of mine....
    Read all about it right here!
    Repairing & Refinishing a Cracked Gauge Cluster
    Old 09-03-2008, 03:52 PM   #3
    tet68's Avatar
    Send tet68:
    Default Re dash
    Old 09-03-2008, 03:57 PM   #4
    Can you post a photo of your dash?
    The curved wood grain dash was only used from 1998-2001, when Mariah went out of business. The dashes used in 2002+ Mariahs were completely redesigned by Sea Fox, the company that now produces Mariahs.
    EDIT- I forgot about the small clusters. I don't believe they are available anywhere either.
    Old 09-03-2008, 04:23 PM   #5
    tet68's Avatar
    Send tet68:
    Default dash pic
    http://www.mariahownersclub.com/foru...1&d=1220458965
    Old 09-03-2008, 05:28 PM   #6
    Yep, those were made in-house at Mariah also. Although I will admit, I didn't research into that design, chances are, you'll have to have it repaired by a plastic repair facility.
    However, there could be a possibility that Sea Fox used the same dash in their early models, you might try dropping them a line to see. Be sure and tell them how similar your dash looks to their early models like the 2003 SX20, and include a photo so they can visually see it.
    Give Stewart a call, he might be able to point you in the right direction.
    Stewart Mitchell
    Customer Service
    Sea Fox and Mariah Boat Co.
    (843) 761-6090 Extension 33
    [email protected]
    Good luck with it, and keep us updated!
    There are 367 users
