Tach Wiring Question
Still having issues with my tach:mad:...before I rip it out and send it back to Faria, can anyone provide me with information on where the Tach wires into the ignition system so that I can check the wiring connections?
Any info (or pics!!!) would be greatly appreciated! :wink_thumbup: |
Hi ewcjoro,
Have you had a chance to look at the Merc Manual for your 5.7, as a gold member, you have access to it. The GM5057-RemovalInstall.pdf indicates that the main engine harness connection is located near the rear of your motor by the distributor and the GM5057-ElectricalSystems.pdf indicates the tach wire comes out of the Ignition Control Module and is gray for the THUNDERBOLT IV and V ignition systems. Make sure the tach's got a good ground too. Good luck, WetWilly |
Thanks, found the info in the manuals.
Re-did the connection, still no worky. Guess I will have to take out the Tach and ship it off to Faria. :( |
| All times are GMT. The time now is 10:32 AM. |
