Fuel Capacity Problem
Old 07-28-2008, 03:00 AM   #1
97 Z222's Avatar
97 Z222 is currently offline
My Model: 97 Z222 Shabah,7.4L carb, Bravo I 21p stainless 3 blade prop
Send 97 Z222:
Default Fuel Capacity Problem
According to my manual, I should have a 50 US gal fuel tank or 187 litres. Last week my fuel gauge was reading empty, so I went over to the marina and filled up. I was surprised when it only took 108 litres to fill up. This ment that I should have 79 litres remaining. The next day when I got down to empty again, I kept boating for about an hour and a half when the boat ran out fuel. I should have had lots of fuel left. So after an embaracing tow back to shore, I put 20 litres in by jerry can and drove over to the marina and to my surprise, the pump reads 117 litres after the fuel spills out the vent line. Total fuel put in is 137 litres. Where is the other 50 litres of fuel? Does anyone know what the sending unit looks like in the tank? Has anyone else had this problem? Is it possible that I didn't get a 50 gal tank?
  • Old 07-28-2008, 06:55 AM   #2
    Hi 97 Z222,
    According to the 97 Mariah brochure, your Shabah has a 49 gallon tank or 223L, but we all know that 49 gal is only about 185L.
    Now if your Shabah was perfectly level, you might get all 185L into the tank, but as most of our boats sit low in the stern when at rest in the water, and if I remember correctly, the vent tube is near the fuel gauge and they normally sit at the back of the tank.
    So as the fuel level in the tank rises, it will reach the vent passage before filling completely up so there will always be an air pocket in the tank.
    So its how low your stern is that will determine how much fuel you can actually put in.
    If you have a trailer, go to the gas station when your Shabah’s nearly empty, put a small level on the floor to ensure the tank is level or slightly down towards the bow and see how much fuel you’re able to pump in. Remember to slow the fill when you get over 100L as there will be a lot of splashing in the tank and some of it can get pushed out the vent.
    Good luck,
    Old 07-28-2008, 12:58 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    The fuel capacity should be written on a label on the top of the tank. Flip the back seat forward, and open the little hatch in the floor just forward of the engine. It should reveal the gas tank, sender connections and the label. You might also want to check the sender's resistance. On the '95 202 it reads between 10 ohms (full) to 250 ohms (empty).
    My Mariah
    Old 07-28-2008, 02:19 PM   #4
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    Just going by personal experience here...
    My boat holds approx 23gal / 87L and I have yet to fill it to the brim. I normally fill up a 25L (jerry can) on Friday or Saturday and either get a whole weekend out of it or stop by a gas station (on the road) for another 25L on Sunday. Purely dependant on engine use of course.
    Now I know everyone boats differently and we all know the 3.0L sips fuel vs a 7.4L. But, I don't really have a need to keep the fuel tank completely topped up at all times. Take what I need, use it, replace when needed. On a 6hr trip we did take along an 10L jerry "just in case". Which we did end up using.
    As Z202 mentioned, pull back the seat and find your tank and inspect the label on top of the tank. Mine was there and plenty easy to read.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 07-28-2008, 05:00 PM   #5
    Originally Posted by 180diablo View Post
    ... we all know the 3.0L sips fuel vs a 7.4L...
    Jeez, don't drive the knife any deeper or anything!
    This year's definitely been the most expensive boating year so far, but it's worth it, especially on a Mariah!
    Mariah made their own fuel tanks for each and every model, they were molded to fit the open areas. Mine has a 56 gallon tank, but for some reason won't ever hit a true fillup, even from empty. I think it's a pretty common occurrence, plus figure in the size of the fuel sender and everything too, that would take up some space in the tank as well. Also factor in things like temperature too, gas expands at higher temps. I've filled the boat up, left it out in the heat, and later found a fuel trail from the vent. There's all kinds of variables that might explain the situation for you.
    Old 07-28-2008, 11:07 PM   #6
    lomitabob's Avatar
    lomitabob is currently offline
    My Model: 2001 Z250 Shabah 7.4LMPI Bravo I
    Gallery Images: 12
    Send lomitabob:
    An additional note...in my Z250 if I run out of gas it takes 10 gal before the fuel pickup will pickup enough to start the 7.4 MPI engine. I found this out the hard way!
    Old 07-29-2008, 09:37 AM   #7
    Looks like you're going to need two jerry cans just to get restarted and a third to get back...
    Old 08-04-2008, 07:16 AM   #8
    97 Z222's Avatar
    Send 97 Z222:
    Thanks for the replies. Just got back from a week of boating at Canum Lake in the interior of British Columbia. Well, I didn't run out of fuel this week. For now I am just treating the tank like it is only 100 litres until I get my fall winterizing and check up with the mechanic. I'll have him check it out then. Still a head scratcher though. I think that wet willy might be on to something with the level of the tank when filling in the water. I'm going to have to try a level land fill up and see if that makes a difference.
    Old 08-05-2008, 01:09 AM   #9
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Just got back from the annual Ohio River/Kentucky Lake run. 23 guys and 5 boats.
    Filled up the tank with 115gal. If your Diablo 180 sips gas ,I guess mine guzzles it like a college kid drinks cheep beer on spring break! I get 2.2mi/gal.
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 08-05-2008, 12:59 PM   #10
    Originally Posted by z275st View Post
    I get 2.2mi/gal.
    How are you able to calculate this, with the Smartcraft? What RPM and speed were you running at? Man that's so cool, I'd love to find out where my optimum MPG is. (besides idle speed)
    Gas Tank Capacity steve Original Mariah Talk 14 08-05-2024 12:30 PM
    fuel tank capacity jchemotti Mercury MerCruiser 9 07-04-2008 05:41 AM
    Found a problem ... 180diablo Chit Chat/Off-Topic 6 05-20-2008 05:07 PM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    does anyone know the fuel capacity of a 1995 216 Talari? docblackmon Original Mariah Talk 16 08-20-2007 03:39 PM
    Total Threads: 13,324
    There are 271 users
