engine hatch
Old 09-18-2022, 11:42 AM   #1
randy731 is currently offline
My Year: no
Send randy731:
Default engine hatch
Have a new to me 1994 212Z Batteries are dead don't how to get electric hatch open to get at batteries. Please help!!!
  • Old 09-19-2022, 09:00 AM   #2
    Sparks&Stripes is currently offline
    My Model: Jubilee Z244
    My Engine: 350 Mag Alpha One
    Send Sparks&Stripes:
    Default Re: engine hatch
    See if you can lift it up enough to get your hand in there to take the pin(s) out of the actuator(s). If not you could always hook a battery up to the switch to activate it seperately.
    Dan
    Upstate NY
    98 Mariah Jubilee Z244 - 350 Mag MPI/Alpha1G2
    88 Seebold Eagle 21 Closed Bow - 175 Suzuki OB
    97 Celebrity 240 Cuddy - 7.4 Merc/Bravo1
    88 Larson Delta Conic 250 Aft Cabin - 5.7 Merc/Alpha1G1
    86 Thompson Open Bow - 3.0 Merc/AlphaG1
    Old 09-21-2022, 06:09 PM   #3
    Vacation Dave's Avatar
    Vacation Dave is currently offline
    My Model: 1995 Z220 Talari 7.4L Bravo I
    My Engine: 7.4L Bravo I
    Send Vacation Dave:
    If you can get enough room to pull the back seats forward. Make sure the area in front of the seats is clear. They are hinged and heavy so be careful to guide them down.
    Once seats are pulled forward, you can access the pins under the hatch. You may need to jimmy the hatch a little to get the pins out. Note there is a smallball bearing that needs to compress when pulling out the pins. You only need to pull the upper pins out.
    When the pins are removed from both sides, use a couple 2x4's or something the hold the hatch in the up position. Maintain equal support to both sides of the hatch. Then you can trouble shoot the wiring issue
    One of my actuators is not working and I have not found a wiring fix yet. It would be great if you can add information to this thread when you get the wiring fixed.
    ****Engine Hatch Cover**** wpd575 Introductions 3 04-10-2020 05:01 PM
    Engine hatch motor Cassearcy General Maintenance 5 03-04-2017 02:19 PM
    redoing engine hatch ctbartgis Introductions 2 08-07-2013 02:44 AM
    Engine Hatch Brad97 Original Mariah Talk 6 10-08-2012 11:25 PM
    Engine Hatch Binding adornare Original Mariah Talk 3 06-12-2008 05:55 PM
    Total Threads: 13,324
    There are 338 users
