Location of Air Temp Sensor? ('96 Z240)
Old 08-07-2021, 02:04 PM   #1
MuNaught is currently offline
My Engine: 350 w/ Bravo 3
Send MuNaught:
Default Location of Air Temp Sensor? ('96 Z240)
I'm getting a readout of "00" in air mode, which implies the sensor has a loose/unplugged wire. Connections are solid on the back of the readout PCB.
I have searched and read through the multiple threads on the air/water temperature readout. I see how to adjust the offsets via pots and the location of the water temperature sensor which is on the transom mounted Airmar ST63.
Unfortunately the threads I reviewed nor the electrical diagrams make clear where the air temperature sensor is located.
Does anyone know where I can find the air temperature sensor probe on a 1996 Talari Z240?
    Air Temp Sensor jayws6 General Maintenance 0 04-11-2014 12:47 AM
    air/sea temp meter wiring schematics for 96 talari z240 Txtruckerpaul Original Mariah Talk 5 11-21-2013 03:48 AM
    alarm from high temp sensor jsewall82 Original Mariah Talk 7 06-29-2013 01:59 AM
    Water Temp and Air Temp Panel brettk Original Mariah Talk 4 02-20-2009 09:20 PM
    Air Temp Sensor rjobe Original Mariah Talk 5 09-17-2007 02:45 AM
    There are 499 users
