1994 Z240 7.4 Merc won’t fire
Old 07-25-2021, 05:20 PM   #1
Moni’s Mariah is currently offline
My Engine: 7.4 Merc Bravo 1
Send Moni’s Mariah:
Default 1994 Z240 7.4 Merc won’t fire
HELP. Just bought a 1994 Mariah, seller hot wired it in order to get it sold. Put it back together correctly, everything works and motor runs perfectly. After thirty minutes at relatively low power on the lake, I pushed it up and at 3000+ RPM the engine quit. Hasn’t fired since. Replaced coil, signal amp, and optical sensor under the distributor cap. No luck. I have 12 volts at the coil, engine turns over ok, definitely have gas at the carb. Just will not fire. All gauges work, oil pressure ok, I get a little pressure during cranking. Any ideas?
Note, kill switch ok, all CBs check good.
  • Old 07-26-2021, 10:21 AM   #2
    Sparks&Stripes is currently offline
    My Model: Jubilee Z244
    My Engine: 350 Mag Alpha One
    Send Sparks&Stripes:
    Default Re: 1994 Z240 7.4 Merc won’t fire
    Did you replace distributor cap and rotor? When I got my boat it would idle great all day but like you say when I get up higher in the rpms is was cutting out and falling on its face as if I was turning the key off and on. Lots of corrosion under the cap when I replaced it...
    Dan
    Upstate NY
    98 Mariah Jubilee Z244 - 350 Mag MPI/Alpha1G2
    88 Seebold Eagle 21 Closed Bow - 175 Suzuki OB
    97 Celebrity 240 Cuddy - 7.4 Merc/Bravo1
    88 Larson Delta Conic 250 Aft Cabin - 5.7 Merc/Alpha1G1
    86 Thompson Open Bow - 3.0 Merc/AlphaG1
    Old 07-26-2021, 02:39 PM   #3
    Send Moni’s Mariah:
    Thx
    The cap and rotor looked like new, the engine had obviously been worked on as all hoses, belts, etc looked like they had been recently replaced. The engine didn’t sputter at all, just flat quit. I still suspect a wiring, short, or safety feature shut down the engine…..a clue might be that the water temp gauge only got up to 110 or so after thirty minutes of low power running?
    Old 07-27-2021, 04:27 AM   #4
    Send Moni’s Mariah:
    Mechanic informed me that the oil pressure Switch, not sender, can fail and cause a no spark condition, even if the oil pressure is in limits! Ordered a new switch, I’ll post if it works. Thx all!
    Old 07-27-2021, 09:23 AM   #5
    Got to love electrical gremlins!
    Dan
    Upstate NY
    1995 talari z240 7.4 merc bravo3 richmil79 Introductions 0 05-21-2019 08:41 PM
    4.3 vortec won't fire, help needed Budsybill Original Mariah Talk 27 05-22-2014 11:28 PM
    Information Please: 1994 Z240 Mariah Davanti Daxgirl Introductions 2 02-07-2009 08:52 PM
    Fire Port jmills224 Original Mariah Talk 10 04-08-2008 10:16 PM
    1994 Z240 Talari on eBay WetWilly Mariah Boats For Sale & Wanted 1 03-25-2008 01:18 PM
    There are 362 users
