First cruiser Z 276 MCC
Old 05-02-2021, 10:59 AM   #1
Stevieu1 is currently offline
My Model: Z276 mcc
My Engine: 7.4 L
Send Stevieu1:
Default First cruiser Z 276 MCC
We put a down payment on a 97 z 276 mcc. Pending sea trial. Any advice is appreciated. Is there anything specific I should look for during the trial? Common issues etc...
File Type: jpg Screenshot_20210429-194740_Facebook.jpg (68.3 KB, 22 views)
File Type: jpg Screenshot_20210429-194652_Facebook.jpg (82.5 KB, 20 views)
File Type: jpg Screenshot_20210429-194648_Facebook.jpg (52.4 KB, 20 views)
  • Old 05-03-2021, 12:27 AM   #2
    dustinnantais is currently offline
    My Model: Z275 Shabah
    My Engine: 7.4L Merc Mag Bravo3
    Send dustinnantais:
    Default Re: First cruiser Z 276 MCC
    Congrats! I love that model. Would have bought one in a second but we found a 97 Z275 and had to pull the trigger quick (market is crazy here in Toronto area). We have the same interior upolstery lol - flashback to the 90s. And same engine. We're just getting an inspection, tune up, gelcoat repair + polish.
    Personal advice, get everything you can tuned up and restored right off the bat. Very likely not going to be anything serious wrong with the hull or engine if it's got low hours - Mariah's are tanks.
    Stevieu1 likes this.
    Thank you dustinnantais for this useful post!
    Stevieu1 (05-03-2021)
    Old 05-03-2021, 01:40 AM   #3
    'Hudson River Steve' is probably the most knowledgeable member here on this site regarding that particular model. Hopefully he'll chime in with his thoughts.
    As a general rule of thumb when buying a Mariah, this tutorial might be helpful: Buying a Used Mariah?
    Old 05-03-2021, 12:02 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    As all said, pretty well built boat, but heavy. At low speed turn wheel hard left or right and listen for any clunking which would indicate worn u joints or gimbal bear. Sea trial is important but while on the trailer with outdrive all the way up, check the condition of the belows, also grab the large forward prop and try pushing and pulling on it. If it moves considerably there is gear and bearing wear in the lower unit. One last thing, check the condition of the oil pan. 7.4's use steel and can rust out. Climb on top of engine and hang upside-down like a monkey to get a good look, especially in the corners of the pan. Good luck.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-03-2021, 02:05 PM   #5
    My Model: Z276 mcc
    My Engine: 7.4 L
    Send Stevieu1:
    He said he replaced the gimbal bearing, bellows and boots since hes had it. Hes had it 3 years. I will ask for all receipts and repair documentation. He had it running on muffs. It ran nice and smooth. It started easily. After about 10 mins the overheat alarm went off. He shut it down. The muffs had slid off the intake holes. Tried again and it kept heating up. He said they would inspect and fix before sea trial. He thinks it's the impeller. He said he would return the down payment if it did not pass the sea trial.
    Old 05-03-2021, 05:20 PM   #6
    My Model: Z280
    The impeller would definitely burn up without water. Ask him if they got all the impeller vanes out, so they don't get stuck in one of the coolers and cause issues later on. Check the play on those props. Bravo3's typically last about 500hrs on these heavy boats.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-03-2021, 05:28 PM   #7
    My Model: Z276 mcc
    My Engine: 7.4 L
    Send Stevieu1:
    It's an Alpha outdrive. That's exactly what he thinks happened. When the muffs slid off a piece of the impeller my have broken off and plugged something.
    Old 05-03-2021, 07:23 PM   #8
    My Model: Z280
    Are you sure it is an Alpha drive. That is a big boat for an Alpha?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-03-2021, 07:45 PM   #9
    My Model: Z276 mcc
    My Engine: 7.4 L
    Send Stevieu1:
    Sorry my bad...its a bravo. Update...the impeller was shot. He just called me. He's putting in a new one right now. Sea test set for Saturday, weather permitting. Oneida lake can get angry this time of year. I hope the winds are down.
    Old 05-09-2021, 02:28 AM   #10
    My Model: Z276 mcc
    My Engine: 7.4 L
    Send Stevieu1:
    Water test went pretty good. We bought the boat! I had a marine mechanic friend with me for piece of mind. Only thing I need to do before I use it is replace the steering cable.
    268 Cabin Cruiser Delta Original Mariah Talk 2 11-29-2016 06:50 PM
    Wanted: Need a ladder top cover for my 2001z268 cruiser Steve6075 Mariah Parts For Sale & Wanted 2 06-21-2016 09:34 PM
    Lineup Changes - No More Cruiser Dredd Sea Fox - Mariah Talk 3 09-27-2011 07:31 PM
    2000 268 Cruiser (Daytona, FL) - Needs Engine - $20k/obo ShabahZ280 Mariah Boats For Sale & Wanted 3 01-14-2009 06:49 PM
    New G270 Cruiser ShabahZ280 Sea Fox - Mariah Talk 0 10-24-2008 07:19 PM
    There are 244 users
