-   -   Shabah Z212 Gas Tank (http://www.mariahownersclub.com/forum/original-mariah-talk/12792-shabah-z212-gas-tank.html)
Shabah1253 05-20-2020 12:53 AM
I am new to this group and unable to find this question in a previous thread.
Does anyone know how the gas tank is removed from a 94 Shabah Z212? I can access the hatch under the rear seat and see the fuel sender unit and hose connections, but before removing, or cutting, the carpet I wish to know if the floor has to be cut to access the entire gas tank?
In addition, does anyone know where a new 40 gallon gas tank can be purchased? There is a label on it that lists Kracor Model 6-7052. I can find where Kracor was purchased by Yahama, but having no luck in getting any information.
Thanks and Regards;
Scott
mikeyt 05-20-2020 01:00 AM
Re: Shabah Z212 Gas Tank
Have a look at this thread cuz that's what you are in for. Finding a matching fuel tank for a 25+ yr old boat will be difficult. Best you will likely be able to do is find one that fits.
Shabah1253 05-20-2020 11:53 PM
Thanks Mikeyt. This is not what I was hoping to hear. Looks like I have my work cut out for me.
Thanks Again
Scott
Shabah1253 08-11-2020 02:42 PM
I was able to remove the gas tank easier than thought. I removed the seats and the port side panel to access the carpet. This was the most difficult. Then I was able to peel the carpet back to access the plywood floor. The plywood floor is layed out in sections and fastened with s/s flat head screws. No cutting required. Fortunately there is 1 piece of plywood covering the gas tank section. Once this was removed, there are 4 braces, 1 each corner. Remove these braces, and hoses, etc. and the 40 gallon tank will lift right out.
Because this is a plastic tank, and not aluminum, I was able to thoroughly clean the tank and did not have to replace it.
Thank you...
Scott
