-   -   Trailer suggestions for 202 Shabah (http://www.mariahownersclub.com/forum/original-mariah-talk/12789-trailer-suggestions-202-shabah.html)
Cappy 05-16-2020 09:01 PM
I have a 1994 202 Shabah 19' 10"
The boat is in great condition and the engine was completely rebuilt this winter. The trailer, however, is pretty rickety.
Any suggestions on the type of trailer I should get and where? I am thinking one with some type of braking system and maybe a 2 axle trailer or would that be overkill? Had 2 blow outs driving the boat home after purchase last year and never want that experience again.
I read that a trailer that is rated for a heavier boat than what one has will result in a bumpy ride so I need one that fits the boat properly.
We will be doing lots of towing and I want to upgrade from the white knuckle experience that the current 25 year old trailer provides.
Would love something in the $4000 range.
Thoughts?
mmendenhall 05-17-2020 02:06 AM
Re: Trailer suggestions for 202 Shabah
What kind of trailer did it come with? Was it the original Prestige trailer or something else?
My 1998 Shabah 202 came with the original Prestige 2 axle trailer and it rides perfect. I would certainly recommend something similar if you can find it.
jarwiebe 05-17-2020 03:06 PM
I have a Shorelander 5,000 lb GVWR tandem axle and it handles like a charm.
Had a flat on one of the tires one time while towing with a F150, and never noticed a thing until a passerby pulled up beside me and point to my trailer indicating I had a problem. The tire was shredded but no damage to the rim.
I have since installed a tire pressure monitoring system to warn me if a tire goes low.
Cappy 05-17-2020 03:34 PM
It is a Prestige single axle trailer. Lots of bouncing, feels like the boat and trailer will pop off at anytime. It probably is safe but still provides a white knuckle experience.
Do you have a 202 Shabah on that trailer? The 202 Shabah is no where near 5000 lbs so I would think it does not have the weight to hold a trailer rated for a 5000 lb boat to the ground.
I do like the dual axle option for the reason you stated above. Trying to jack up a boat trailer safely with a car jack is next to impossible. My only thought is they may not make a properly fitted dual axle trailers for this lighter weight, small boat.
jarwiebe 05-17-2020 03:54 PM
Mine is a Z210 and loaded with a full tank of gas I scale at 4,400 lbs.
Cappy 05-17-2020 05:48 PM
I imagine the smaller 202 would be closer to 3000 lbs which would be too light for your trailer. I guess I'll need to go to some marina's that sell trailers. Online, the boat trailer companies only have brochureware web pages with find a dealer and no hint of pricing.
Any idea what the price range a small dual axle that fits the 202 would be? $3000? $5000?
jarwiebe 05-17-2020 07:18 PM
I bought my boat and trailer as a package in 2011 and have never checked out trailer prices so can't help there.
Just to clarify, I scale at 4,400 lbs, that is trailer, boat, fuel and contents. My trailer is just over 900 lbs itself.
TN_Diablo 05-17-2020 10:00 PM
If you are willing to spend a little extra then go for an aluminum salt water trailer with torsion axle(s). I purchased mine from Loadmaster about 20 years ago and I love it. No rust, no maintenance except brakes and still looks mostly like new. You would measure your bunks and everything on the old trailer and they get it really close but it is all adjustable to get just right. My trailer could be adjusted to fit your boat I'm sure. Also I really like the longer tongue than the Prestige had which makes it pull and back much better. I imagine they still use private party capable of dropping a trailer depending where you are for not a great amount extra. I had a deal with the dealer when I got my boat that the trailer was just on loan until I got a trailer with brakes. We used to tow it with a Dodge Caravan and it was night and day (Prestige vs Loadmaster).
Mine has surge brakes and they have worked fine but need to keep the master cylinder dry which I cover to keep rain out. Electric was an option I know. Mine is single axle but tandem would really be better for lots of miles and POM. Another recommendation I have is to use Goodyear Endurance tires, not the older Marathon. I got good service from the first set of Marathon and never had a failure but my spare (also Marathon) separated. The new Endurance appears to be a much better tire and maybe the best rated trailer tire out there. So I have Endurance on the trailer and a cheapo $50 Chinese spare which I hope to never need. Mine are a full load range up from what I need so you must adjust the inflation pressure to your actual weight rather than max inflation pressure. There is a lot of poor advice and practice on proper inflation pressures for trailer tires and generally it is NOT the max inflation pressure on the tire sidewall. Anyway when I do that it gives a really smooth ride. Our Pilot (08) pulls our boat on the x-way and until you find a hill or big bump you don't notice it's back there.
My trailer was closer to $2500 but that was long time back. I hope you don't get sticker shock if you price one today. They don't have all the integrated features and clever design of some steel bass boat rrailers I've seen but I still think the best all around in design and service.
It's worth a few phone calls to find out. I'll post a picture if you like.
Cappy 05-18-2020 08:54 PM
Called the local Marina where my boat is at. The sell Yacht Club trailers. They have a dual axle with braking that they say fits the boat for $3000. I do like that it is under my $4000 range.
I will look at one when I pick up the boat and if I like will order one.
