House Panel Power
Old 03-16-2020, 07:03 PM   #1
crishe3 is currently offline
My Model: Se198
Send crishe3:
Default House Panel Power
I have a 1997 198SE with one battery. I have tried to install BlueSea's "add a battery" system with the charging relay. I cant seem to find where the power to the house panel is coming from. I have looked at the the wiring diagrams on here but they are not very helpful in determining where the power to the accessories is coming from. Currently there is only one line going from the battery to the starter, so the power to the other accessories has to be fed from the starter. I have attached the wiring diagram from the box, it seems simple, but i cannot find the line I need to connect that runs to the house panel.
In lieu of finding where the line comes from the back, Can I disconnect the current power line from the battery to the ignition switch and run a new line to the the house battery and connect to the battery? is there anything being powered from the ignition switch that would, the only things that work while the key is off is the trim and the bilge pump. which do not
any help is greatly appreciated.
  • Old 03-16-2020, 08:30 PM   #2
    Lancer is currently offline
    My Year: 2003
    My Model: Z 235 Devanti
    My Engine: 7.4 Bravo 1
    Send Lancer:
    Default Re: House Panel Power
    yes you are right. look at the panel and you will have one wire energising the panel. get a color and try to find it in the back.that wire is probably fed through the key switch on lug.my 235zc has a separate #10 gauge wire to the back that has a eye connector i put under the thumb screw on the battery
    but this is just a charger. you can isolate the two batteries with a manual isolation switch.
    Texas in the house 76sporty Introductions 0 01-26-2017 09:31 PM
    Interior Panel Lose (Throttle Mounting Panel) iced98lx Original Mariah Talk 6 06-07-2016 08:32 PM
    House battery replacement lanierz260 Original Mariah Talk 3 05-05-2012 01:11 AM
    lost electrical power after main fuse panel bfinn Original Mariah Talk 0 06-15-2011 04:36 AM
    There are 534 users
