1998 Z252 Auto bilge pump replacement
Hi Guys
my automatic bilge pump switch has broken , i think its in the engine bay. the pump works fine from the manual switch, i was wondering if it was difficult to replace. i think its made by attwood, any one got a clue how to go about it Ed Cossey ( sonny boy) |
Sometimes the float switch gets dirty and prevents it from functioning properly. First step is to try some bilge cleaner. I usually pour a bit in there, then add some water to help it slosh around. I'll drive for probably about 30 minutes then pump it out. This will usually break up any marine growth or potential problem causers. If this doesn't work, you can try and manually repair it yourself, but it might be easier to just replace it. Replacing it shouldn't be a horrible task, and might only take about 30 minutes. The hardest part is figuring out how to reach it! Just make sure you get the right GPH rating. Mariah equipped their boats with some of the fastest pumps available in that size range.
bilge pump
thanks chris
I think i'll just replace it. the switch is about 30 Dollars. that way i'll be shure its ok all the best Ed (Sonny boy ) |
| All times are GMT. The time now is 02:23 AM. |
