Test boating 1997 shabah 183 se. any advice?
Old 08-27-2019, 03:03 AM   #1
Teaches08 is currently offline
My Model: Shabah 183 se
My Engine: 4.3 merc
Send Teaches08:
Default Test boating 1997 shabah 183 se. any advice?
I have a purchase agreement with dealer for 3,000 on a 97 shabah that he took on trade and wanted the older model gone quick at boat show. I inspected hull and engine and trailer all look good. Passed pressure test new looking tubes and belts on engine. Seals look good it’s a 4.3 l. Merc engine. Trailer has new tires and belts. Other than some rips in upholstery everything looks good. I’m really shocked at this boat.
I am a brand new boater this would be my first. Any advice when I go out for the test drive.?
Thanks in advance
  • Old 08-27-2019, 06:33 PM   #2
    Default Re: Test boating 1997 shabah 183 se. any advice?
    Read.... Buying a Used Mariah
    Old 08-27-2019, 07:39 PM   #3
    My Engine: 4.3 merc
    Send Teaches08:
    Thank you. I did do all of those and looked good. I’m more curious what I should check in water
    Thankd
    Old 08-27-2019, 09:17 PM   #4
    Check that it accelerates properly, doesn't leak and turns easily from side to side without 'growling'. If there is a growl coming from stern, its likely the gimbal bearing that needs replacing and that means removing the outdrive.
    Things like slow speed wandering (which stern drives are prone to do) and porpoising can be easily fixed with a set of Smart Tabs.
    Old 08-28-2019, 03:52 AM   #5
    My Engine: 4.3 merc
    Send Teaches08:
    Thank you! All tested out well it’s mine I’m looking forward to ownership. I appreciate all the advics
    1997 210SE Shabah - Boat cover advice needed Grierk Original Mariah Talk 2 05-03-2013 05:23 PM
    Ready to buy a 95 Z272 Barchetta, advice on compression test results? JoeDoyle Original Mariah Talk 2 03-31-2011 01:02 AM
    1997 z242 advice cliff717 Original Mariah Talk 8 09-23-2010 02:46 PM
    New to Boating need advice Jasonl Introductions 3 07-08-2008 05:43 PM
    There are 332 users
