95 Talari won't Plain out. Help!!
Old 05-17-2019, 11:26 PM   #1
fdheil is currently offline
My Model: Z210 Talari limited
My Engine: 5.7
Send fdheil:
Default 95 Talari won't Plain out. Help!!
I'm having troubles with my oat not planing out. When I accelerate the nose comes up but it won't plain. The RPMs are good and the trim is good as far as I can tell. It does work. last summer I did get in some shallow water and the prop did bottom out for a short distance. The boat did however seem to operate normally for the rest of the summer. The next year, last year, is when I started having the problem. After some research I think maybe the prop spun the hub and it is starting to spin when the power is increased to go. I have taken the prop to a shop to get a new hub installed. My question is, Do any of you have any other ideas as to what could be wrong? Thanks.
  • Old 05-18-2019, 01:46 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 95 Talari won't Plain out. Help!!
    If it's not the prop hub then it could be your engine coupler spun. Let's hope it was the prop hub
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Diff between Talari 220 vs Talari Z220 ckstiles Introductions 2 04-29-2013 02:23 AM
    Difference between 240 Talari & 240 Z Talari ? wunn Original Mariah Talk 3 07-03-2009 03:03 PM
    There are 297 users
