Engine hatch rocker switch wiring
Hi everyone. I'm looking for the correct way to wire the rocker switch that controls the linear actuators. My 1994 Talari's owners manual does not include that wiring data. I can wire the rocker using a standard way for a dpdt switch and can reverse the polarity, but when I hook up the actuators I loose the voltage. I'm missing a couple of jumpers some place. My last resort will be to set up a separate dpdt switch in the back and wire it directly to the battery. HELP !!
Re: Engine hatch rocker switch wiring
My actuators for the hatch and the captains chair was not working. Found these two are wired together. Found Buss fuse panel Under steering wheel, fuse was bad, put in new fuse, only getting 6-8 volts at the actuators. Then noticed thin corrosion on the fuse panel itself where fuse is held in place. Roto wire wheeled it. Put fuse and wires back. Problem solved! Thank God!!!
Can you tell me more about how you fixed this? My stereo, hatch lift and seat keeps going out and now wont turn on at all.
Sent from my SM-G950U using Tapatalk |
| All times are GMT. The time now is 04:39 PM. |
