Any ideas?
Old 08-23-2018, 06:47 AM   #1
John822179 is currently offline
My Model: Z225 Davanti
My Engine: 5L FL V8
Send John822179:
Default Any ideas?
Hi fellow Mariah lovers,
I have a 1994 Z225 which is my pride and joy!
She’s a bit of a project, I’ve been working on her since the end of 2016 and am steadily getting her ship shape 😀
The engine is now running sweetly after the replacement of the fuel pump, starter motor, alternator and a set of Drive belts.
I’ve also got a lot of the electrics sorted.
However, I’m stuck with a couple of problems.
1. My Lowrance 3500 displays E- and I can find no reference as to what this means.
2. Above the Lowrance, is a mechanical digital counter, see attached photo. Anyone know what it’s counting? It’s not an hours run, ‘cause I’ve got one of those and it ain’t working either!😂😂
Any info more than welcome
File Type: jpg 531EA803-1ABC-4273-A500-B5A71A268476.jpg (107.0 KB, 24 views)
John822179
Mariah Z225 5L V8
Keep the dry side up
  • Old 08-23-2018, 01:29 PM   #2
    Default Re: Any ideas?
    The counter at the top is an hours meter. Probably been disconnected. Follow the wiring.
    The Lowrance problem likely means; a) the unit is pooched and needs replacement, b) the transducer isn't working or (assuming it is mounted on the floor in front of the engine) c) the transducer is no longer epoxied mounted to the floor. You might find a manual for it here on the site but they are easy to replace and it doesn't have to be a Lowrance.
    Old 08-25-2018, 06:58 AM   #3
    My Engine: 5L FL V8
    Send John822179:
    Hi mikeyt,
    Many thanks for your response.
    I did wonder if it was an hours meter, but why fit 2 and why give it a Reset button?
    I had hoped to find a troubleshooting guide for the Lowrance, but have failed so far.
    I did contact Lowrance in the UK, but they were no help at all.
    Have a fabulous weekend
    John822179
    Mariah Z225 5L V8
    Old 08-25-2018, 03:06 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I believe the counter at the top is an odometer. Do you have a paddle wheel mounted on the transom? If so that is the input to the odometer. Few of them still work.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-25-2018, 09:39 PM   #5
    I just looked back at my response. Steve has it right and honestly, that's what i meant to say....
    Old 08-26-2018, 02:52 PM   #6
    My Engine: 5L FL V8
    Send John822179:
    Hi mike & Steve,
    Many thanks for your input. I can’t think why I didn’t think of the Odometer 😩😩
    Presumably, a paddle wheel will rotate, generating pulses, which bumps the counter..
    The obvious question is, where is the paddle wheel?
    It’s been a few months since I had her out of the water, but I have no memory of anything even remotely paddle wheel like!!
    Anyone got a photo?? Google doesn’t seem to know anything.
    John822179
    Mariah Z225 5L V8
    Old 08-26-2018, 04:03 PM   #7
    brentsc's Avatar
    brentsc is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 MAG MPI
    Send brentsc:
    on the lowrance depth finder issue, mine was doing the same thing... it was the transducer 'puck' that is a through the hull. Mine had come loose and was just rolling around in the engine compartment. Once I repositioned it back in its spot, it worked again. As noted, they can come loose from their epoxy set.
    I have a 98 Z210 and it was located sightly left of center board, right under the engine on the bottom hull.
    Old 08-27-2018, 11:38 AM   #8
    My Model: Z280
    Here is a picture from an earlier post about Smart Tabs. You can see the paddle wheel sender just to the right of the tab. The location of the paddle wheel on your boat may vary left to right.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Any ideas SUN N FUN Mercury MerCruiser 1 06-17-2015 09:21 PM
    AC needed for Z302 (any Ideas?) HowardsZ302 Original Mariah Talk 19 07-23-2013 12:52 AM
    logo / graphic ideas Oregondunes Chit Chat/Off-Topic 2 07-22-2011 05:53 PM
    Custom Graphics Ideas??? josh3204 Projects 8 02-08-2011 04:23 AM
    Help with decal ideas stereoman405 Original Mariah Talk 7 04-17-2009 05:01 AM
    There are 533 users
