Engine died suddenly
Old 05-21-2018, 04:23 PM   #1
smds is currently offline
My Engine: Mer 502
Send smds:
Default Engine died suddenly
New Mariah owner here. I picked up a 1995 talari z240 with the mpi 502 a couple weeks ago. Boat has run great in the 3 trips to the lake until yesterday when we were heading back to the ramp. After running across the lake for 15 minutes we got insight of the boat ramp and the engine just died suddenly. Like I flipped the kill switch. It would turn over and fire for half a second and then die. It did this repeatedly. Ended up paddling to the ramp against the current and wind for about an hour. I’m thinking it’s not getting fuel since it fires but won’t stay running. Any ideas before I tear into it?
  • Old 05-23-2018, 07:51 AM   #2
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    Default Re: Engine died suddenly
    There alot of things...ignition switch go bad..oil pressure kill switch...coil..short in wires..fuel pump..fuel filter..ignition..water in gas..efi...carb..crank sensor...with electronic stuff can work when cold acts up when hot..wire fall off...
    Old 05-30-2018, 02:25 AM   #3
    My Engine: Mer 502
    Send smds:
    I finally got it squared away. There were plastic chunks in the aluminum fuel cell that got picked up and lodged in the antisiphon valve. This burned out the mechanical fuel pump.
    Old 05-31-2018, 02:55 AM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Thanks for the follow-up.
    Old 06-03-2018, 06:06 AM   #5
    My Engine: Mer 502
    Send smds:
    Hopefully it will help someone out in the future. I know I read just about every thread I could on this site about fuel issues and it helped me track down the problem. I will say that every marine mechanic I talked to about it said that the antisiphon valve can cause issues if they get clogged or corroded and they all recommended to drive it out with a punch and get rid of it.
    Old 06-03-2018, 02:19 PM   #6
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Yikes! Bad idea to remove it. It prevents filling your bilge with fuel if a leak occurs in a pipe below the level of the top of the tank. it is a Coast Guard requirement to have one installed on all new boats whenever the fuel lines go below that level. I would never remove mine.
    Old 06-03-2018, 03:25 PM   #7
    My Engine: Mer 502
    Send smds:
    I have not removed mine but all three mechanics said the exact same thing.
    Old 09-11-2018, 06:53 PM   #8
    Macker29 is currently offline
    My Model: Diablo
    My Engine: 4.3 Mercruiser
    Send Macker29:
    How difficult was it to get access to the anti-siphon valve?
    Old 10-01-2018, 04:12 AM   #9
    My Engine: Mer 502
    Send smds:
    Remove the fuel line from the tank. Then take a wrench and remove the nipple the fuel line slides over from the 90* fitting on the tank. The anti siphon is inside the nipple.
    Old 10-01-2018, 12:51 PM   #10
    Towers1538 is currently offline
    My Model: 182
    My Engine: 4.3L
    Send Towers1538:
    Sounds like a quick mechanic fix for which they will charge for a two-hour job.
    4.3 Mercruiser Died, Won't start jeffrey.young1 Mercury MerCruiser 2 07-13-2015 01:16 AM
    It just died on me Jgos929 Original Mariah Talk 13 10-18-2013 09:30 PM
    Suddenly my Boat won't start & trim doesn't work guyjusthere Mercury MerCruiser 16 01-06-2013 05:56 PM
    Mariah Shabah 180 won't turn over suddenly? VF143_vet Mercury MerCruiser 5 07-04-2010 06:32 PM
    There are 350 users
