1996 Shabah 180 smart tabs SX
Old 07-08-2017, 02:11 PM   #11
fix1frank is currently offline
My Model: Z212
My Engine: 5.0L Alpha1 Gen2
Send fix1frank:
Default Re: 1996 Shabah 180 smart tabs SX
For reference.
Sent from my XT1030 using Tapatalk
1994 Shabah Z212
5.0L Alpha1 Gen2
Thank you fix1frank for this useful post!
Firestone (07-08-2017)
  • Old 07-08-2017, 02:33 PM   #12
    My Model: Z202
    Send Firestone:
    Looking good Frank. How is that high 5 working for you?
    John
    Old 07-08-2017, 11:59 PM   #13
    My Model: Z212
    Send fix1frank:
    Using it for ballast at the moment, great for pulling but too low for efficient cruising
    1994 Shabah Z212
    5.0L Alpha1 Gen2
    Old 07-11-2017, 12:28 AM   #14
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    Thanks the measurements and info. I going to measure it up tomorrow and if numbers look right order up a set set smart tabs sx.
    Old 07-11-2017, 12:39 PM   #15
    My Model: Z212
    Send fix1frank:
    Call them! The owner answered my call and he was very helpful.
    Found good price at Hodges Marine.
    Huge improvement
    1994 Shabah Z212
    5.0L Alpha1 Gen2
    Old 07-25-2017, 12:32 AM   #16
    My Engine: 4.3 Merc
    Send pole trick:
    well I ordered the smart tabs sx with the 60lbs Actuators. To put them on took about 40 minutes. Set up in number 3 hole, haven't test any other settings. It gets on plane about half the time and the bow never gets high enough that I can't see in front of me when planning off. So far are very impressed with them. Zero ill handling effects all been positive changes. My friend said it rides like a completely different and a better boat. I Just went river running only so far. I'll add some pictures of rear end of them installed on 1996 180 Shabah. Best $125.00 I spent so far on improvements to a boat.
    I been testing props for last couple of weeks trying to get 3 good props dialed in. One for serious sking and tubing or full load with cooler unknown 17 pitch stainless with lots of cup. Got one for 2 or 3 people cursing\top end 23 pitch lasar 2. Looking at testing a 4 blade mercury aluminium 20 pitch for everyday use.
    Thank you pole trick for this useful post!
    Firestone (07-25-2017)
    Old 07-25-2017, 01:59 AM   #17
    My Engine: 4.3 Merc
    Send pole trick:
    I thinking on putting my 23 lasar 2 back on and see if any changes to rpm or mph with tabs installed.. I was testing a unknown very old n.o.s Michigan wheel 19 pitch yesterday with the new tabs on first run with them and it was over reving at w.o.t. I normally only run mercury props....my cousin marina had this n.o.s 19 no cup 3 blade aluminum in there back room for years...told me to try it. Even my friend asked What s up with that prop...Not for my application....lol
    Old 07-25-2017, 04:48 PM   #18
    My Engine: 4.3 Merc
    Send pole trick:
    Here is tabs installed
    Tried to rotate pic couldn't from my phone...?
    Old 07-26-2017, 05:34 PM   #19
    My Model: 180 Diablo
    My Engine: 3.0 Mercruiser
    Send TN_Diablo:
    We tried to tell you that Some here were probably prepared to hunt you down if you put a foil back on.
    I thought about the white version and wondered how it would look but decided black to match the motor. With the white ones it's sort of shouting at you to clean the hull now
    Thank you TN_Diablo for this useful post!
    pllevine (07-26-2017)
    Old 07-26-2017, 05:37 PM   #20
    Send TN_Diablo:
    Sorry, it might have been someone else who was thinking about a foil on the lower unit. We send the dogs after them if they do that.
    1996 Z210 Smart Tabs jsewall82 Original Mariah Talk 18 03-10-2015 01:16 PM
    Smart Tabs ColoradoDiablo Other For Sale 3 03-16-2014 05:23 PM
    smart tabs?? tazzyou Original Mariah Talk 11 02-06-2011 12:03 AM
    Smart Tabs karmann Original Mariah Talk 13 07-22-2009 06:21 PM
    Total Threads: 13,324
    There are 255 users
