-   -   Cuddy light switches help!!!! (http://www.mariahownersclub.com/forum/original-mariah-talk/11591-cuddy-light-switches-help.html)
tpdtopcop 07-04-2017 06:48 PM
1 Attachment(s)
Guys have a quick question on my cuddy lights,
I was upgrading to led's but I think all my switches are bad. I tested with bulbs direct and they work. I then bypassed the switch by cutting the switch out and the bulbs work. So I am thinking all the little push button switches are bad. Can I get replacement switches for my cuddy lights?
Attachment 6987
pllevine 07-04-2017 08:01 PM
Re: Cuddy light switches help!!!!
I was upgrading to led's but I think all my switches are bad. I tested with bulbs direct and they work. I the. Bypassed the switch but cutting the switch out and the bulbs work. So I am thinking all the little push button switches are bad. Can I get replacement switches for my cuddy lights?
Attachment 6987
You do know that the LEDs have polarity?
tpdtopcop 07-04-2017 08:44 PM
In regards to above. I believe I have tried them both ways. Even the original bulbs do not work when utilizing the switch.
TCJ95Z-235 07-04-2017 10:56 PM
These switches were fairly common in boats, conversion vans & r.v.'s
Try contacting JUDCO Manufacturing in Harbor City, California 1-310-534-0959
Judco,Judcomfg,Judco Mfg,Judco Manufacturing,Judco Manufacturing Inc,electric switches,switch,switches,pushbutton switches,rocker switches,wire harnesses,toggle switches,slide switches,injection molding,PCB,keypads,toggle switches,focuslite,focus-lit
If they can't sell directly to you I'm sure they'll be able to get you in touch with a vendor in your area.
Hope this helps
