95 Shabah 202
Old 07-04-2017, 06:42 PM   #1
Mariahsteve12 is currently offline
My Model: Z202
My Engine: 350
Send Mariahsteve12:
Default 95 Shabah 202
Out riding yesterday and the boat is running like a top. Then out of nowhere it shuts down. It fires right back up but will only idle along. After a while it would pick back up and run good but then it would shut down again. Once smelled a little gas like it was flooded but I was running steadily down the lake when it shut down. Any ideas?
  • Old 07-04-2017, 08:00 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 95 Shabah 202
    Could be the Ignition coil overheating.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Mariahsteve12 (07-05-2017)
    Old 07-05-2017, 12:09 AM   #3
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    Have you tried checking your kill switch? The wiring and switch itself was bad on mine. That could be part of the problem.
    Old 07-05-2017, 10:15 PM   #4
    My Model: Z202
    My Engine: 350
    Send Mariahsteve12:
    I haven't tried that but I will. Thank you.
    Old 07-06-2017, 08:05 PM   #5
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    I'm still learning the marine side of things but if a car did that the first thing I would check is the fuel pump/filter and the fuel pressure to the carb/EFI.
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    Old 07-20-2017, 09:16 PM   #6
    My Model: Z202
    My Engine: 350
    Send Mariahsteve12:
    I have not but I will. Thank you
    Total Threads: 13,324
    There are 347 users
