-   -   2200zc (http://www.mariahownersclub.com/forum/original-mariah-talk/11552-2200zc.html)
rgeissmann 06-19-2017 08:46 AM
2200zc
Good day everyone !
I'm a new owner of 1995 2200ZC on the Lake Geneva in Switzerland.
I'm depseratly looking for an elctrical network map of this boat !!
Would you happen to have that ? If not, do you know where I can find it ?
Thanks a lot for your help.
Rom
Firestone 06-19-2017 09:04 AM
Re: 2200zc
The wiring diagrams from a 1995 Mariah can be found in the contributing members section. It's only $15 for a year and it keeps this site going. All kinds of other good stuff in there as well.
rgeissmann 06-19-2017 09:22 AM
Re: 2200zc
Ok thanks, I've just subscribed !
However, the problem is the driver seat and the motor "hood". Both of them are electric and are activated by 2 separated switches located on the right of the seat (just below the throttle). None of them are working... Is there a fuse to change ? as I cannot find anything about that in the wiring schematics.
Thanks very much for your help.
Rom
fix1frank 06-19-2017 10:42 AM
Re: 2200zc
Electricity + H2O = corosion, not every time but it is common enough to justify starting at the fuse block check power at each end if the fuse and inspect the wire connection's at the fuse block. Clean if indicated and a little dielectric grease can save you issues.
It's a start.
Sent from my XT1030 using Tapatalk
rgeissmann 06-19-2017 10:49 AM
Re: 2200zc
Thanks Frank,
Would you know which fuse i should check ? Is it the "ACC" one ?
Thx for your help
Firestone 06-19-2017 12:38 PM
Re: 2200zc
Yeah. Mine sre the same. Have to chase them down. On the Hatch I ran new wires to the battery and made a new switch box that is next to the seat. More convenient then going to the dash everyyime. Plus wired to battery I can turn off all the power and add still close the hatch
rgeissmann 06-19-2017 01:08 PM
Re: 2200zc
http://imageshack.com/a/img922/7295/RzRR1U.jpg
But did you finally manage to track him down ?
On my dash I do not see any fuse which could be used for the hatch and driver seat (see image above, it seems I only have 9 fuses (3 of them are hidden by the wheel)) !!
It may a good idea to do a direct wiring as you say but if possible, I would like to avoid that !
Thanks again for your help
Firestone 06-19-2017 02:35 PM
Re: 2200zc
No. I did not track it down. Was going to start at the wires at the base of the seat and test with a volt meter to see if it was just the seat motor.
rgeissmann 06-19-2017 02:44 PM
Re: 2200zc
Ok thanks for your help !
Let's hope someone managed to track it down ! if it exists....
