What to buy?? Please help me decide
Old 08-10-2016, 02:44 AM   #21
chrissbee77 is currently offline
Send chrissbee77:
Default Re: What to buy?? Please help me decide
Do these motors have a idle air control valve?
  • Old 08-10-2016, 09:58 AM   #22
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Is your motor carburated or injected? If carb then no. If injected then yes.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-12-2016, 09:41 PM   #23
    Send chrissbee77:
    Oaky so I had a friend go through the carb , he called today with it ready for pickup. Removed about a tablespoon full of sand from the carburetor filter. He suggested that I clean the fuel water separator and lines out, turns out my boat doesn't have a spectator on it. What's the best way to go about cleaning the lines and the sand out of the motor? Please don't tell me I have to remove the fuel tank
    Old 08-13-2016, 10:34 PM   #24
    My Model: Z280
    If the only fuel filter you have is on the carb inlet then you should plan on adding a second pre-filter. It can be a simple see thru inline filter if you have a rubber line leading into the carb. If the line going into the carb is a hard line then you may as well add a water separating fuel filter between the tank and the fuel pump. They are simple enough to add, they often come with a bulkhead mount. This should trap any "sand" before it clogs up your carb. Just change the filter each season or every 50 hrs....just like your oil.
    Sent from my iPad using Tapatalk
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-16-2016, 04:29 AM   #25
    Send chrissbee77:
    Hudson River Steve, is there a particular inline filter you recommend? I have a metal link going from the fuel pump to the carb with a clear plastic hose as a return line. I have a couple Fram G2's in a box not being used.
    Old 08-16-2016, 08:14 PM   #26
    My Model: Z280
    Since you have a hard line going from your fuel pump to the carb I wouldn't mess with an inline filter. I would add a water separating fuel filter between the tank and the fuel pump. You can't go wrong with a Sierra 18-7775-1 kit. It has the bracket, filter element and the two pipe plugs. All you need to add are two brass hose barbs to fit the fuel line that you will be cutting into and two good quality stainless steel hose clamps. You can get the barbs and clamps at any home store.
    https://www.amazon.com/Sierra-18-777.../dp/B000N9MTFC
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-16-2016, 08:27 PM   #27
    Send chrissbee77:
    Hudson River Steve; sounds like a good Saturday project, I'll knock it out this weekend.
    Old 07-17-2021, 03:57 PM   #28
    A little late but still good .....
    Total Threads: 13,324
    There are 470 users
